Home » Archived » BIRT » Desgin Engine API : help, doc, or something else ...
Desgin Engine API : help, doc, or something else ... [message #56590] Tue, 12 July 2005 10:47 Go to next message
Originally posted by: joel.adm-concept.com
Hello
I try to use the Design Engine API from Java code. I search for
documentation on the methods.
The tutorial online explains how create a new Report, but it is not
complete and i need to modify an existing report. And the "openDesign"
method failed, so i need help.
Someone can help me ?
Thx
Re: Desgin Engine API : help, doc, or something else ... [message #56966 is a reply to message #56590] Tue, 12 July 2005 14:54 Go to previous messageGo to next message
The DE API JAVA docs are part of the help inside Eclipse. After you
install the BIRT plugins, go to Help-> HelpContents ->BIRT Developer
Guide->Reference->API Reference -> Report Object Model API Reference
--Rima Kanguri
Re: Desgin Engine API : help, doc, or something else ... [message #56994 is a reply to message #56590] Tue, 12 July 2005 15:52 Go to previous messageGo to next message
What problem do you have?
For example, I had a problem creating a datasource and to use the openDesign
function, and the problem was fixed, with ..
It seems like an environment problem. Can you check whether the
org.eclipse.birt.report.data.oda.jdbc is in your eclipse plugin directory?
If yes, you need to give the argument when you run your code:
-DBIRT_HOME="your eclipse home".
Or you can specify your own BIRT_HOME directory. But the following plugins
and
jar should exist in your BIRT_HOME/plugins:
org.eclipse.birt.core
org.eclipse.birt.data
org.eclipse.birt.data.oda
OK
"Bazinou" <joel@adm-concept.com> escribi
Re: Desgin Engine API : help, doc, or something else ... [message #57225 is a reply to message #56966] Wed, 13 July 2005 03:11 Go to previous messageGo to next message
Oh !! I didn't see that ... it will be very useful ... thank you !!
> --Rima Kanguri
Re: Desgin Engine API : help, doc, or something else ... [message #57252 is a reply to message #56994] Wed, 13 July 2005 03:15 Go to previous message
It's exactly the problem i had. I could open a report without
datasource, but when i try to open one with datasource, it failed ! But
now with your help it runs. I need just to do a setEngineHome before
design. I did it for run the report, and i have not the idea to do it
here. So i'm stupid.
Thank's
> From: Yu Li
> and
> OK
> "Bazinou" <joel@adm-concept.com> escribió en el mensaje
> news:db0l5u$fpt$1@news.eclipse.org...
>>Hello
>>Thx
Previous Topic:Image with links map
Next Topic:Problem with date and sql statement / filter
Current Time: Thu Jul 17 19:50:42 EDT 2025
Powered by FUDForum. Page generated in 0.04118 seconds
