Home » Archived » M2M (model-to-model transformation) » [ATL] ATL 2 API changes and NullPointerException
[ATL] ATL 2 API changes and NullPointerException [message #56507] Tue, 07 August 2007 05:55 Go to next message
Originally posted by: r.c.ladan.tue.nl
I converted from ATL 1 to ATL 2.0.0rc2, but I get a NullPointerException
when calling it from Java:
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:144)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:65)
at meta.presentation.MetaEditor.doATLTransformation(MetaEditor. java:381)
MetaEditor.java:381 :
this.amh.saveModel(this.models.get("OUT"), outModel);
using:
AtlModelHandler amh
ByteArrayOutputStream outModel
this.models.get("OUT") retrieves ASMEMFModel OUT from a HashMap. It is
created as:
ASMEMFModel outputModel;
outputModel = ASMEMFModel.newASMEMFModel("OUT", "OUT",
this.metaModel, this.ml);
outputModel.setCheckSameModel(false);
using:
ASMEMFModel metaModel;
protected EMFModelLoader ml;
Changing the second "OUT" string to "" or null doesn't help.
Any ideas?
Rene
Re: [ATL] ATL 2 API changes and NullPointerException [message #56589 is a reply to message #56507] Tue, 07 August 2007 09:26 Go to previous messageGo to next message
Hi Rene,
Could you please use bugzilla to discuss this issue?
Frédéric Jouault
Rene Ladan wrote:
> java.lang.NullPointerException
> at
> at
> using:
> AtlModelHandler amh
> created as:
> outputModel = ASMEMFModel.newASMEMFModel("OUT", "OUT", this.metaModel,
> this.ml);
> using:
> Any ideas?
> Rene
Re: [ATL] ATL 2 API changes and NullPointerException [message #56670 is a reply to message #56589] Wed, 08 August 2007 03:44 Go to previous message
Frédéric Jouault wrote:
> Hi Rene,
Done. The bug number is 199211 .
Rene
> Rene Ladan wrote:
>> NullPointerException when calling it from Java:
>> at
>> at
>> using:
>> AtlModelHandler amh
>> is created as:
>> this.ml);
>> using:
>> Any ideas?
>> Thanks,
>> Rene
Previous Topic:[ATL] ACG documentation available on the Wiki
Next Topic:[ATL] How to chek if the model handler is installed
Current Time: Mon Jul 21 21:10:48 EDT 2025
Powered by FUDForum. Page generated in 0.27632 seconds
