makefile [message #56354] |
Thu, 02 January 2003 20:24  |
Originally posted by: katia.vivax-tech.com
Hi to All,
I have an error in my makefile which is like this:
objects = hello.o tpl2doc.o
hello : $(objects)
gcc -o hello $(objects) -L /usr/bin/gcc -lstdc++
gcc -o tpl2doc $(objects) -L /usr/bin/gcc -lstdc++
$(objects) : hello.cpp tpldoc.cpp
gcc -c hello.cpp
gcc -c tpl2doc.cpp
all :
${MAKE} hello
PHONY : clean
clean :
-del hello.exe $(objects)
-del tpl2doc.exe $(objects)
I did not find documentation how to write a good makefile for eclipse for
more than one cpp file. Can somebody point out my error, or provide a URL
with info?
Any Help will be gratly appreciated !
Re: makefile [message #56587 is a reply to message #56449] |
Fri, 03 January 2003 16:08  |
Thanks for the answer !
This is my first encounter with non-automaticly generated makefile, so it
was very helpfull. I am using linux, but got the makefile from windows FAQ
for CDT
(none available for linux) so that why is: del hello.exe :) my mistake.
BuD wrote:
clean
> > clean :
> should be:
> ..PHONY : clean
> clean :
> ;) BuD
> "BuD" <bud_s2460@hotmail.com> wrote in message
> news:av3vd2$lrk$1@rogue.oti.com...
> > Hi Kate,
> > I'm no expert on make but maybe i can give you a shove in the right
> > direction ;)
> > You dont mention wether you are using linux or windows.
> > Some general issues I can see are that:
> > > hello : $(objects)
> > should be:
> > hello : $(objects)
> > gcc -o hello hello.o -L /usr/bin/gcc -lstdc++
> > gcc -o tpl2doc tpl2doc.o -L /usr/bin/gcc -lstdc++
> > and:
> > > gcc -c hello.cpp
> > > gcc -c tpl2doc.cpp
> > should be:
> > hello.o : hello.cpp
> > gcc -c hello.cpp
> > tpl2doc.o : tpldoc.cpp
> > gcc -c tpl2doc.cpp
> > and
> > > PHONY : clean
> > > clean :
> > should be:
> > .PHONY : clean
> > clean :
> > -del hello.exe tpl2doc.exe $(objects)
> > ==== linux specific ===========
> > If you are using linux:
> > double check the path to gcc is correct in the -L switch ("find -type
> > f -name *gcc* -print" should help you locate the right location)
> > change -del to -rm in the clean section
> > remove the .exe extension from hello.exe and tpl2doc.exe in the clean
> > section.
> > ======end linux specific======
> > ==== win specific ===========
> > If you are using windows I found that I had to do a bit of fiddling to get
> > it all working.
> > The following works well for me in win2k - there may be a better way tho
> > First add the path to the bin directory of MinGW to your system PATH
> (right
> > click on My Computer>properties>advanced>enviromentvariables).
> > Modify the:
> > to:
> > gcc -o hello hello.o -lstdc++
> > gcc -o tpl2doc tpl2doc.o -lstdc++
> > Then make a batch file in your project directory called make.bat with the
> > contents.:
> > mingw32-make -f makefile %1 %2
> > In eclipse in the C++ projects view right click your
> > project>properties>c/c++ project then uncheck the use default build
> command
> > and type make.bat in the box.
> > ==== end win specific ===========
> > Go through the whole make file and make sure that you have used a single
> tab
> > to indent the required lines as make is exteremly fussy about this. When
> you
> > have done it save the project.
> > Now try to rebuild the project, if it doesnt work or if it does but you
> want
> > to know why you may want to have a look at
> > http://www.gnu.org/manual/make/html_mono/make.html#SEC_Conte nts
> > hf
> > BuD
> > "Kate" <katia@vivax-tech.com> wrote in message
> > news:av2op2$4r5$1@rogue.oti.com...
> > > Hi to All,
> > > hello : $(objects)
> > > gcc -c hello.cpp
> > > gcc -c tpl2doc.cpp
> > > all :
> > > ${MAKE} hello
> > > PHONY : clean
> > > clean :
> for
> URL
> > > with info?
FUDForum. Page generated in 0.04572 seconds
