Re: Recipe framework gone? [message #56387 is a reply to message #56359] |
Wed, 08 July 2009 14:35   |
Hi Antony,
state of now Recipe is considered deprecated for oaw5. Until now we have no volunteers for this component willing to migrate.
"Old oaw stuff" will be mostly the same, but since namespaces changed during migration to Eclipse Modeling projects must be migrated. Migration effort
is relative few.
Kind regards,
~Karsten
On 08.07.09 20:09, Sven Efftinge wrote:
> Hi Antony,
> the recipe framework is not part of Xtext.
> All secondary oAW components (recipe, XWeave, etc.) will be updated and
> further developed as soon as there are people pushing it forward. You
> might try to trigger Markus Völter (the original author) or find any
> other volunteers.
>> If it has been dropped - would the old oaw stuff be compatible with
>> TMF models/generated code (it's all Ecore under the covers...)?
> I'm pretty sure that there's no explicit dependency to Xtext.
> So it should work. That said, I'm not so sure if there are dependencies
> to Xpand. So you might be forced to use Xpand from oAW 4.3.1 (which
> works with TMF Xtext) in order to use Recipe from oAW 4.3.1.
> It's maybe best to ask in the openarchitectureware.org forum.
> Cheers,
> Sven
Re: Recipe framework gone? [message #56703 is a reply to message #56570] |
Thu, 09 July 2009 08:01  |
Thanks, Sven.
I've asked at oaw, and if they're not interested I'll host it/maintain
myself :)
It's a nice little tool - I think it's of quite limited use - normally I
find I can prevent the need for the checks it does - but occasionally it
proves very handy indeed.
FUDForum. Page generated in 0.03541 seconds
