Home » Newcomers » Newcomers » Cannot Print from Eclipse
Cannot Print from Eclipse [message #56327] Fri, 22 April 2005 17:22 Go to next message
Originally posted by: jaishannon.gmail.com
I've run into a problem with printing from Eclipe. The menu item under
File-->Print is disabled and I have not found any way of enabling it. I'm
running Eclipse 3.0.2 in Fedora Core 3. I cannot print under any
perspective. Any ideas would be greatly appreciated.
JS
Re: Cannot Print from Eclipse [message #56344 is a reply to message #56327] Fri, 22 April 2005 17:27 Go to previous message
I am no expert on this but from a previous post:
Afaik there are only limited printing support for Linux.
From the SWT Faq:
Q: Why is the Print menu item disabled in Eclipse on Motif?
A: Printing on Motif requires that Xprint be installed on your machine.
A good FAQ regarding Xprint can be found at
http://xprint.mozdev.org/docs/Xprint_FAQ.html
Q: Why is the Print menu item disabled in Eclipse on GTK?
A: Printing on GTK has not been implemented yet. You can use the External
Tools support in Eclipse to print files using lpr or some other printing
utility.
HTH
Darins
"JS" <jaishannon@gmail.com> wrote in message
news:008368724fd2e10c0a09ee3f9c337212$1@www.eclipse.org...
> Hello,
> JS
Previous Topic:Implementing editor-dependant menus
Next Topic:API Javadocs from eclipse
Current Time: Sun Jul 27 01:45:02 EDT 2025
Powered by FUDForum. Page generated in 0.29878 seconds
