Home » Modeling » OCL » Comparison operators
Comparison operators [message #56317] Wed, 21 May 2008 04:24 Go to next message
Hei,
From reading the spec. Is it always valid to compare (=) an x of type X against
an y of type Y, given X and Y conform to OclAny? Especially, it is not checked
if X conforms to Y or Y conforms to X, so:
"hello" = 5
is a well formed OCL expression?
Felix
Re: Comparison operators [message #56334 is a reply to message #56317] Wed, 21 May 2008 11:45 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Felix,
That is the way I read the spec, because = is defined for OclAny. It is
also defined separately for types that do not conform to OclAny, such as
the collection types and the tuple types.
The parser used to over-constrain this operation, checking that the
arguments are of related types, but that is fixed in the 1.2 release.
Christian
Felix Dorner wrote:
> Hei,
> against an y of type Y, given X and Y conform to OclAny? Especially, it
> is not checked if X conforms to Y or Y conforms to X, so:
> "hello" = 5
> Felix
Re: Comparison operators [message #56350 is a reply to message #56334] Wed, 21 May 2008 12:34 Go to previous messageGo to next message
Christian W. Damus wrote:
> Hi, Felix,
Okay, so the good news is that we have the same view on that. Do you know why
the collection types are actually NOT subtypes of OclAny?
This seems confusing.
Felix
Re: Comparison operators [message #56365 is a reply to message #56350] Wed, 21 May 2008 12:51 Go to previous messageGo to next message
Hi, Felix,
I think it's just because they are values, not objects. Thus, a lot of
the operations defined for OclAny just don't make sense (oclIsNew,
oclIsUndefined, oclIsInState, etc.)
Christian
>> Hi, Felix,
>> is also defined separately for types that do not conform to OclAny,
>> such as the collection types and the tuple types.
> know why the collection types are actually NOT subtypes of OclAny?
> Felix
Re: Comparison operators [message #56389 is a reply to message #56365] Wed, 21 May 2008 15:49 Go to previous messageGo to next message
> Hi, Felix,
Yeah, but the primitive types are also values, and, in contrast, conform to OclAny.
Maybe MOF based models do not support the concept of redefinition? Then it
wouln't be it wouldn't be possible to redefine the "=" operator for the
collections..
Re: Comparison operators [message #56547 is a reply to message #56365] Fri, 23 May 2008 04:41 Go to previous message
>>Do you
I found it, p. 199:
A simple set inclusion semantics for subtype relationships as
described in the next section would not be possible due to cyclic domain
definitions if OclAny were the supertype of
Set(OclAny).
Now I have to find out what that means..
Previous Topic:Bug in OCLAbstractAnalyzer
Next Topic:ocl collection
Current Time: Sun Aug 31 15:17:17 EDT 2025
Powered by FUDForum. Page generated in 0.03643 seconds
