[Resolved] Generation for only one file [message #559569] |
Fri, 17 September 2010 08:55 |
jeremie Messages: 233 Registered: April 2010 |
Until now, with xtext 1,0, the workflow of the generator project, launch the generation for all files in the src/model folder.
Is it possible to launch the generation for only one file ?
For example, launching the generation for the file : src/model.hcdg.adapt.
I write this in the workflow :
var modelPath = "src/model/hcdg.adapt"
Bit, when I launch the workflow, I have an exception :
426 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow workflow.LanguageGenerator: java.util.zip.ZipException: error in opening zip file
java.lang.RuntimeException: Problems running workflow workflow.LanguageGenerator: java.util.zip.ZipException: error in opening zip file
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:82)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: org.eclipse.emf.common.util.WrappedException: java.util.zip.ZipException: error in opening zip file
at org.eclipse.xtext.mwe.PathTraverser.traverseArchive(PathTraverser.java:63)
at org.eclipse.xtext.mwe.PathTraverser.findAllResourceUris(PathTraverser.java:44)
at org.eclipse.xtext.mwe.PathTraverser.resolvePathes(PathTraverser.java:33)
at org.eclipse.xtext.mwe.Reader.invokeInternal(Reader.java:152)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:31)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:80)
... 3 more
Caused by: java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:114)
at java.util.zip.ZipFile.<init>(ZipFile.java:131)
at org.eclipse.xtext.mwe.PathTraverser.traverseArchive(PathTraverser.java:52)
... 12 more
thanks,
Jérémie
[Updated on: Tue, 21 September 2010 09:52] Report message to a moderator
FUDForum. Page generated in 0.03893 seconds
