type hinting for arrays [message #56203] |
Mon, 01 October 2007 08:30  |
hey folks,
i'm not sure if this has been requested before, but it would be great if pdt would recognize objects
returned in an array:
class Foo {
public $var1;
* returns an array of Foo objects
* @return Foo[] array of Foo objects
public static getInstances() {
return array(new Foo(), new Foo());
foreach (Foo::getInstances() as $foo) {
$foo->var1 = "bar"; // after $foo->, ctrl+space will display $var1
when returning a single object, pdt parses the phpdoc and everything works great, but here we have
an array, so pdt had to parse through the code ("foreach") as well, in order to apply the correct
object type to the variable $foo.
is that even possible? that would make pdt even greater than it already is! :)
cheers,
-nico.
FUDForum. Page generated in 0.02819 seconds
