JAXB - compiling schema [message #56151] |
Thu, 09 December 2004 15:01  |
Originally posted by: ronball.mho.com
Other than executing an Ant build, can you compile the schema inside
Eclipse?
Re: JAXB - compiling schema [message #56174 is a reply to message #56151] |
Fri, 10 December 2004 06:14  |
Ron,
Is your question specifically about JAXB, which has nothing to do with
this project, or are you asking about EMF's XML Schema to Ecore
conversion from which you can generate a JAXB-like Java implementation
of your schema's model? We have command line tools for those that you
can invoke programmatically...
> Eclipse?
Re: JAXB - compiling schema [message #593175 is a reply to message #56151] |
Ron,
> Eclipse?
FUDForum. Page generated in 0.42794 seconds
