Home » Language IDEs » Java Development Tools (JDT) » OC4J Crash while hot code replacement.
OC4J Crash while hot code replacement. [message #558111] |
Fri, 10 September 2010 08:50 |
daniel Messages: 2 Registered: September 2010 |
Junior Member |
Good Morning,
I'm an happy user of Eclipse, but the company where are working for are using OC4J.
I really don't know which is the correct configuration to debug appications and do hot code replacement, some time works for a period and don't work in some days, I explored ALL the eclipse configuration for this feature and now i'm stuck:
When I stop the thread, and try to change also a simple value of a string, after recompiling OC4J crash, and this is the error:
Hope that someone can help me.
Thank you in advanced.
bye.
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d800a5f, pid=980, tid=284
# Java VM: Java HotSpot(TM) Client VM (1.5.0_16-b02 mixed mode)
# Problematic frame:
# V
--------------- T H R E A D ---------------
Current thread (0x00a367e8): VMThread
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00a36ca8, EDX=0x00a36cd8
ESP=0x32d3fc10, EBP=0x32d3fc6c, ESI=0x32e7fc90, EDI=0x00a367e8
EIP=0x6d800a5f, EFLAGS=0x00010202
Top of Stack: (sp=0x32d3fc10)
0x32d3fc10: 00000000 32e7fc90 00a4c0b0 33de9fd8
0x32d3fc20: 00000001 00a367e8 00a36ca8 00a36cc8
0x32d3fc30: 00a36cd4 00a370bc 32d3fd18 00a368b0
0x32d3fc40: 00a36890 00a368a8 00a368b0 00a36c9c
0x32d3fc50: 34528040 00a4c0b0 00a4c0c8 32d3fca4
0x32d3fc60: 24cb22a0 22eebda8 00000000 32d3fca4
0x32d3fc70: 6d800b50 6d814a7a 6d800bfe 00366438
0x32d3fc80: 32e7fc4c 6d800b89 32e7fc90 6d86ad26
Instructions: (pc=0x6d800a5f)
0x6d800a4f: ff 85 c0 0f 84 d8 00 00 00 53 8b 40 04 89 45 fc
0x6d800a5f: 8b 18 4b 0f 88 b7 00 00 00 eb 03 8b 45 fc 8b 40
Stack:
V
V
V
V
C
C
VM_Operation (0x32e7fc4c): change breakpoints, mode: safepoint, requested by thread 0x003675e8
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x334a4590 JavaThread "OracleTimeoutPollingThread" daemon
0x333a5338 JavaThread "HTTPThreadGroup-6"
0x345ad160 JavaThread "HTTPThreadGroup-5"
0x3369ce88 JavaThread "HTTPThreadGroup-4"
0x00366d88 JavaThread "DestroyJavaVM"
0x338286d8 JavaThread "TaskManager"
0x33ab2758 JavaThread "Timer-6"
0x33a5ebc8 JavaThread "Timer-5"
0x336f18b8 JavaThread "SystemThreadGroup-6"
0x33c77da8 JavaThread "SystemThreadGroup-5"
0x339f8f20 JavaThread "SystemThreadGroup-4"
0x336c7be8 JavaThread "Timer-4"
0x338f5fa0 JavaThread "Timer-3"
0x338f5e18 JavaThread "Timer-1" daemon
0x33891950 JavaThread "WorkExecutorWorkerThread-1" daemon
0x338fc8b8 JavaThread "Thread-17" daemon
0x338f3b90 JavaThread "Thread-15" daemon
0x338f1ef8 JavaThread "Thread-13" daemon
0x33907848 JavaThread "Thread-11" daemon
0x33891688 JavaThread "Thread-9" daemon
0x3369c6c0 JavaThread "Timer-0"
0x3311e008 JavaThread "AWT-Windows" daemon
0x33197dc0 JavaThread "Java2D Disposer" daemon
0x33091f40 JavaThread "RMIServer [/0.0.0.0:23943] count:1"
0x33084100 JavaThread "RMIServer [/0.0.0.0:23791] count:1"
0x331d2f00 JavaThread "JMSServer"
0x331f6ac0 JavaThread "WsMgmtWorkScheduler" daemon
0x00a5dbe8 JavaThread "WsMgmtWorkScheduler" daemon
0x00a64fd8 JavaThread "Scheduler ServiceThread"
0x332aa9a8 JavaThread "Timer ServiceThread"
0x33357cf0 JavaThread "Event ServiceThread"
0x33546178 JavaThread "LogFlusher" daemon
0x33860d90 JavaThread "LogFlusher" daemon
0x3348d108 JavaThread "LogFlusher" daemon
0x00a50340 JavaThread "Low Memory Detector" daemon
0x00a4e970 JavaThread "CompilerThread0" daemon
0x00a4da28 JavaThread "Signal Dispatcher" daemon
0x00a4b478 JavaThread "JDWP Command Reader" daemon
0x00a4a210 JavaThread "JDWP Event Helper Thread" daemon
0x003675e8 JavaThread "JDWP Transport Listener: dt_socket" daemon
0x00a3a6e8 JavaThread "Finalizer" daemon
0x00a392b0 JavaThread "Reference Handler" daemon
Other Threads:
=>0x00a367e8 VMThread
0x00a51548 WatcherThread
VM state:at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: ()
[0x00366408/0x00008f18] Threads_lock - owner thread: 0x00a367e8
Heap
def new generation total 3264K, used 2907K [0x02a80000, 0x02e00000, 0x051e0000)
eden space 2944K, 96% used [0x02a80000, 0x02d44a38, 0x02d60000)
from space 320K, 22% used [0x02d60000, 0x02d72348, 0x02db0000)
to space 320K, 0% used [0x02db0000, 0x02db0000, 0x02e00000)
tenured generation total 41652K, used 28801K [0x051e0000, 0x07a8d000, 0x22a80000)
the space 41652K, 69% used [0x051e0000, 0x06e005d8, 0x06e00600, 0x07a8d000)
compacting perm gen total 48128K, used 47898K [0x22a80000, 0x25980000, 0x32a80000)
the space 48128K, 99% used [0x22a80000, 0x25946a78, 0x25946c00, 0x25980000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 C:\Programmi\Java\jdk1.5.0_16\bin\javaw.exe
0x7c910000 - 0x7c9c8000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c901000 C:\WINDOWS\system32\kernel32.dll
0x77f40000 - 0x77feb000 C:\WINDOWS\system32\ADVAPI32.dll
0x77da0000 - 0x77e32000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f21000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77e40000 - 0x77e89000 C:\WINDOWS\system32\GDI32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\MSVCRT.dll
0x76340000 - 0x7635d000 C:\WINDOWS\system32\IMM32.DLL
0x6d740000 - 0x6d8de000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\client\jvm.dll
0x76b00000 - 0x76b2e000 C:\WINDOWS\system32\WINMM.dll
0x6d300000 - 0x6d308000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\hpi.dll
0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d400000 - 0x6d435000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\jdwp.dll
0x6d710000 - 0x6d71c000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\verify.dll
0x6d380000 - 0x6d39d000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\java.dll
0x6d730000 - 0x6d73f000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\zip.dll
0x6d290000 - 0x6d297000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\dt_socket.dll
0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
0x719d0000 - 0x71a10000 C:\WINDOWS\System32\mswsock.dll
0x76ee0000 - 0x76f07000 C:\WINDOWS\system32\DNSAPI.dll
0x76f70000 - 0x76f78000 C:\WINDOWS\System32\winrnr.dll
0x76f20000 - 0x76f4d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f80000 - 0x76f86000 C:\WINDOWS\system32\rasadhlp.dll
0x66750000 - 0x667a8000 C:\WINDOWS\system32\hnetcfg.dll
0x71a10000 - 0x71a18000 C:\WINDOWS\System32\wshtcpip.dll
0x6d540000 - 0x6d553000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\net.dll
0x6d560000 - 0x6d569000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\nio.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76980000 - 0x76a35000 C:\WINDOWS\system32\USERENV.dll
0x5bc70000 - 0x5bcc5000 C:\WINDOWS\system32\netapi32.dll
0x6d070000 - 0x6d1dd000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\awt.dll
0x72f70000 - 0x72f96000 C:\WINDOWS\system32\WINSPOOL.DRV
0x774b0000 - 0x775ed000 C:\WINDOWS\system32\ole32.dll
0x5b180000 - 0x5b1b8000 C:\WINDOWS\system32\uxtheme.dll
0x736d0000 - 0x7371b000 C:\WINDOWS\system32\ddraw.dll
0x73b30000 - 0x73b36000 C:\WINDOWS\system32\DCIMAN32.dll
0x6d2b0000 - 0x6d300000 C:\Programmi\Java\jdk1.5.0_16\jre\bin\fontmanager.dll
0x746b0000 - 0x746fc000 C:\WINDOWS\system32\MSCTF.dll
0x752e0000 - 0x7530e000 C:\WINDOWS\system32\msctfime.ime
0x77b10000 - 0x77b32000 C:\WINDOWS\system32\Apphelp.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
VM Arguments:
jvm_args: -agentlib:jdwp=transport=dt_socket,suspend=y,address=localho st:2553 -Xmx512M -XX:MaxPermSize=256M -DcheckForUpdates=all -Dfile.encoding=Cp1252
java_command: oracle.oc4j.loader.boot.BootStrap
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=C:\Programmi\Java\jdk1.5.0_16
PATH=C:\Programmi\Java\jdk1.5.0_16\jre\bin;C:/Programmi/Java /jre1.5.0_16/bin/client;C:/Programmi/Java/jre1.5.0_16/bin;C: /Programmi/Java/jre1.5.0_16/lib/i386;C:\oracle\ora92\bin;C:\ Programmi\Oracle\jre\1.3.1\bin;C:\Programmi\Oracle\jre\1.1.8 \bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Serena\CHANGE~1\DIMEN S~1\9.1\PROG;C:\WINDOWS\System32\Wbem;c:\Programmi\File comuni\Lenovo;C:\Programmi\File comuni\Roxio Shared\10.0\DLLShared\;C:\Programmi\File comuni\Roxio Shared\DLLShared\;C:\Programmi\File comuni\Roxio Shared\DLLShared\;C:\Programmi\File comuni\Roxio Shared\10.0\DLLShared\;C:\WINDOWS\system32\WindowsPowerShell \v1.0;C:\Programmi\IDM Computer Solutions\UltraEdit\
USERNAME=d.commentucci
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (cores per cpu 2, threads per core 1) family 6 model 7 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 2097151k(1895472k free), swap 4194303k(3728144k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_16-b02) for windows-x86, built on May 28 2008 01:04:49 by "java_re" with MS VC++ 6.0
Current Time: Fri Apr 26 21:37:32 GMT 2024
Powered by FUDForum. Page generated in 0.03234 seconds
