ClassNotFoundException [message #56123] |
Mon, 16 August 2004 00:13  |
Originally posted by: nbhatia.sapient.com
I am just starting out with VE. I am getting the following warning with
some Swing code that I added to my VE class.
+++ Warning +++: Sun Aug 15 23:24:17 EDT 2004 Could not instantiate
javax.swing.border.Border with initialization
string=javax.swing.BorderFactory.createCompoundBorder(Border Factory.createLoweredBevelBorder(),BorderFactory.createEmpty Border(10,10,10,10))
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.ClassNotFoundException:
BorderFactory.createLoweredBevelBorder...BorderFactory.creat eEmptyBorder.10.10.10.10..
org.eclipse.jem.internal.proxy.initParser.Expression.getEval uationTypeClass(Expression.java:62)
The code that is generating this exception is:
countLabel.setBorder(
BorderFactory.createLoweredBevelBorder(),
BorderFactory.createEmptyBorder(10, 10, 10, 10)));
Why am I getting this error? Are there any guidelines that I should follow
when modifying VE generated components?
Thanks.
Naresh
Re: ClassNotFoundException [message #56193 is a reply to message #56172] |
Mon, 16 August 2004 17:40   |
Rich Kulp wrote:
> We don't support border factories well yet. That is on our list. Sorry.
> One thing you could try to see if it works (I'm not sure if it will,but
> it is worth a try):
javax.swing.BorderFactory.createCompoundBorder(javax.swing.B orderFactory.createLoweredBevelBorder(),javax.swing.BorderFa ctory.createEmptyBorder(10,10,10,10))
> It could be because they aren't fully-qualified.
Fully-qualified classname fixed the problem. Now only one problem remains:
When I set the layout to BoxLayout, this statement is inserted:
this.setLayout(new BoxLayout(this, BoxLayout.Y_AXIS));
This looks good, except that when I close and reopen the file, the layout
in the top panel shows the following exception:
layout: java.lang.IllegalArgumentException (IWAV0001E Currently "this"
is not supported)
1) Why is this happening?
2) The error message shows up only in a tool tip in the layout, I could
not find it in the Eclipse log. Is there any where else this might be
logged?
Thanks.
Re: ClassNotFoundException [message #597342 is a reply to message #56123] |
Mon, 16 August 2004 11:23  |
it is worth a try):
Thanks, Rich Kulp
Re: ClassNotFoundException [message #597345 is a reply to message #56172] |
> it is worth a try):
is not supported)
logged?
Thanks.
FUDForum. Page generated in 0.11154 seconds
