Home » Archived » Visual Editor (VE) » ClassNotFoundException
ClassNotFoundException [message #56123] Mon, 16 August 2004 00:13 Go to next message
Originally posted by: nbhatia.sapient.com
I am just starting out with VE. I am getting the following warning with
some Swing code that I added to my VE class.
+++ Warning +++: Sun Aug 15 23:24:17 EDT 2004 Could not instantiate
javax.swing.border.Border with initialization
string=javax.swing.BorderFactory.createCompoundBorder(Border Factory.createLoweredBevelBorder(),BorderFactory.createEmpty Border(10,10,10,10))
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.ClassNotFoundException:
BorderFactory.createLoweredBevelBorder...BorderFactory.creat eEmptyBorder.10.10.10.10..
org.eclipse.jem.internal.proxy.initParser.Expression.getEval uationTypeClass(Expression.java:62)
The code that is generating this exception is:
countLabel.setBorder(
BorderFactory.createLoweredBevelBorder(),
BorderFactory.createEmptyBorder(10, 10, 10, 10)));
Why am I getting this error? Are there any guidelines that I should follow
when modifying VE generated components?
Thanks.
Naresh
Re: ClassNotFoundException [message #56172 is a reply to message #56123] Mon, 16 August 2004 11:23 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We don't support border factories well yet. That is on our list. Sorry.
One thing you could try to see if it works (I'm not sure if it will,but
it is worth a try):
javax.swing.BorderFactory.createCompoundBorder(javax.swing.B orderFactory.createLoweredBevelBorder(),javax.swing.BorderFa ctory.createEmptyBorder(10,10,10,10))
It could be because they aren't fully-qualified.
Thanks, Rich Kulp
Re: ClassNotFoundException [message #56193 is a reply to message #56172] Mon, 16 August 2004 17:40 Go to previous messageGo to next message
> it is worth a try):
Fully-qualified classname fixed the problem. Now only one problem remains:
When I set the layout to BoxLayout, this statement is inserted:
this.setLayout(new BoxLayout(this, BoxLayout.Y_AXIS));
This looks good, except that when I close and reopen the file, the layout
in the top panel shows the following exception:
layout: java.lang.IllegalArgumentException (IWAV0001E Currently "this"
is not supported)
1) Why is this happening?
2) The error message shows up only in a tool tip in the layout, I could
not find it in the Eclipse log. Is there any where else this might be
logged?
Thanks.
Re: ClassNotFoundException [message #56212 is a reply to message #56193] Mon, 16 August 2004 19:39 Go to previous message
Similar problem. We don't support "this" at this time.
See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=69668
This defect actually came around because of the problem of using
BorderLayout(this,...).
Thanks, Rich Kulp
Re: ClassNotFoundException [message #597342 is a reply to message #56123] Mon, 16 August 2004 11:23 Go to previous message
it is worth a try):
Thanks, Rich Kulp
Re: ClassNotFoundException [message #597345 is a reply to message #56172] Mon, 16 August 2004 17:40 Go to previous message
> it is worth a try):
is not supported)
logged?
Thanks.
Re: ClassNotFoundException [message #597351 is a reply to message #56193] Mon, 16 August 2004 19:39 Go to previous message
See
Thanks, Rich Kulp
Previous Topic:ClassNotFoundException
Next Topic:V E on Mac OS X
Current Time: Sat Nov 08 18:01:38 EST 2025
Powered by FUDForum. Page generated in 0.04911 seconds
