Home » Modeling » OCL » Re: IRJA0029W No parser for the "OCL".
Re: IRJA0029W No parser for the "OCL". [message #5006] Mon, 12 February 2007 10:42 Go to next message
Peter,
It's better to ask on the OCL newsgroup, which I've added to the "To" list.
Peter Ladanyi wrote:
> Hi there,
> I'm trying to make run ocl validation on my model but always getting
> exception:
> Warning
> Mon Feb 12 16:25:07 CET 2007
> IRJA0030I The constraint "Example OCL Constraint (Batch Mode)" is
> disabled. It will not be evaluated.
> org.eclipse.emf.validation.xml.ConstraintParserException: IRJA0029W No
> parser is registered for the "OCL" language. Constraints expressed in
> this language will not be evaluated.
> at
> org.eclipse.emf.validation.internal.util.XmlConstraintFactor y.createConstraint(XmlConstraintFactory.java:85)
> at
> org.eclipse.emf.validation.internal.util.XmlConstraintFactor y.createConstraint(XmlConstraintFactory.java:103)
> at ...
> Can anybody write me, what i need to do to solve this kind of trouble ?
> Thanks a lot,
> Peter.
Re: IRJA0029W No parser for the "OCL". [message #5212 is a reply to message #5006] Mon, 12 February 2007 12:22 Go to previous message
Hi, Peter,
Do you have the org.eclipse.emf.validation.ocl feature installed? You
probably do, if you installed the EMFT Validation component. Note that it
depends on the MDT OCL component, so this feature may be installed but
disabled.
You can download OCL from
http://www.eclipse.org/modeling/mdt/downloads/?proj=ocl
HTH,
Christian
Ed Merks wrote:
> Peter,
> list.
>> Hi there,
>> exception:
>> Warning
>> at
>> at
>> at ...
>> Thanks a lot,
>> Peter.
Previous Topic:ocl, uml, can't start.
Next Topic:OCL Performance
Current Time: Fri Jul 04 20:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.04879 seconds
