Home » Language IDEs » Java Development Tools (JDT) » Problem with ant output.
Problem with ant output. [message #56112] Fri, 13 June 2003 08:00 Go to next message
I don't know what Im missing here. I have a normal build.xml which compiles
normally in the dos-prompt. The thing is that when I use it in Eclipse Im
missing a lot of the output. For example, when I do a build (where I compile
one file) I get this in Eclipse:
Buildfile: D:\Project\myproject\build.xml
init:
compile:
BUILD SUCCESSFUL
Total time: 771 milliseconds
But when I do this in dos, I get:
Buildfile: build.xml
init:
compile:
[javac] Compiling 1 source file to D:\Project\myproject\lib
BUILD SUCCESSFUL
Total time: 12 seconds
How do I set Eclipse so I see the javac output? Another things I have
noticed is that I can compile error files through Eclipse.With that I mean
that I get the same output as the first example when I know there is an
error in the file. The error is then shown when I run the program (it can
for example be a missing semicolon). Eclipse dont tell me anything that the
error exist, more than showing it in the task view. Is there some way to
make it stop when there is an error?
This is the tasks I have in the build.xml file:
<target name="init">
<mkdir dir="${build}" />
<tstamp/>
</target>
<target name="compile" depends="init">
<javac classpath = "${classpath}"
srcdir = "${src}"
destdir = "${build}"
deprecation = "on"
<include name="**/*.java"/>
</javac>
</target>
Thanks in advance!
/Mathias Ohlsson
Re: Problem with ant output. [message #56140 is a reply to message #56112] Fri, 13 June 2003 08:35 Go to previous messageGo to next message
Originally posted by: darin_swanson.oti.com
Which compiler are you using? Are you setting the build.compiler property?
javac will attempt to do incremental compiles...from the Ant doc: "
The source and destination directory will be recursively scanned for Java
source files to compile. Only Java files that have no corresponding .class
file or where the class file is older than the .java file will be compiled."
Could this be the case that the .class files is up to date?
If not please log a bug report against platform-ant and we can look into
things more in detail.
Darins
"Mathias Ohlsson" <mathias.ohlsson@enovation.se> wrote in message
news:bccebi$3j6$1@rogue.oti.com...
compiles
compile
> init:
> compile:
> BUILD SUCCESSFUL
> init:
> compile:
> BUILD SUCCESSFUL
the
> <tstamp/>
> </target>
> srcdir = "${src}"
> deprecation = "on"
> </javac>
> </target>
> Thanks in advance!
> /Mathias Ohlsson
Re: Problem with ant output. [message #56410 is a reply to message #56140] Fri, 13 June 2003 08:41 Go to previous messageGo to next message
No, the .class file is not up to date and that isnt the real problem. The
file is found and compiled, that I have checked but its the output in the
console thats missing. It doesnt say that there is x nr of files compiling
nor does it give feedback when there is errors in the file. Although I find
it strange that it can output an .class file with errors in it, the problem
I have is that I lack the information about it.
/Mathias
"Darin Swanson" <darin_swanson@oti.com> wrote in message
news:bccgd0$5ms$1@rogue.oti.com...
compiled."
> Thanks
> Darins
> > Hi,
> compiles
Im
> compile
> > init:
> > compile:
> > BUILD SUCCESSFUL
> > init:
> > compile:
> > BUILD SUCCESSFUL
mean
can
> the
> > <tstamp/>
> > </target>
> > srcdir = "${src}"
> > deprecation = "on"
> > </javac>
> > </target>
> > Thanks in advance!
> > /Mathias Ohlsson
Re: Problem with ant output. [message #56437 is a reply to message #56410] Fri, 13 June 2003 08:51 Go to previous message
We will investigate your bug report.
Darins
news:bccgpl$63l$1@rogue.oti.com...
find
problem
> /Mathias
property?
Java
..class
> compiled."
> > Thanks
> > Darins
> > > Hi,
> > compiles
> Im
> > compile
> > > init:
> > > compile:
> > > BUILD SUCCESSFUL
> > > init:
> > > compile:
> > > BUILD SUCCESSFUL
> mean
an
> can
that
> > the
to
> > > <tstamp/>
> > > </target>
> > > srcdir = "${src}"
> > > deprecation = "on"
> > > </javac>
> > > </target>
> > > Thanks in advance!
> > > /Mathias Ohlsson
Previous Topic:Anyone using MyEclipse?
Next Topic:Feedback on new 3.0M1 smart insert features
Current Time: Thu Jul 24 01:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.05989 seconds
