Home » Archived » XML Schema Definition (XSD) » min/max Occurs
min/max Occurs [message #56097] Tue, 07 December 2004 18:56 Go to next message
Originally posted by: gsauere.yahoo.com
How can I retrieve the value of min/max Occurs in the following example?
<schema xmlns="http://www.w3.org/2001/XMLSchema">
<element name="test1" fixed="string" minOccurs="1" maxOccurs="unbounded"
<element name="test2" fixed="string" minOccurs="2" maxOccurs="unbounded"
</schema>
Re: min/max Occurs [message #56125 is a reply to message #56097] Tue, 07 December 2004 20:26 Go to previous message
Guilherme,
You can't. It's not valid to specify these on a global element
declaration. You can specify it on a local element declaration, in
which case there will be an XSDParticle to hold that information.
></schema>
Re: min/max Occurs [message #593147 is a reply to message #56097] Tue, 07 December 2004 20:26 Go to previous message
Guilherme,
></schema>
Previous Topic:min/max Occurs
Next Topic:JAXB - compiling schema
Current Time: Wed Jul 09 07:58:38 EDT 2025
Powered by FUDForum. Page generated in 0.03865 seconds
