choice or sequence min/max occurs [message #55964] |
Mon, 06 December 2004 17:09  |
Originally posted by: rob.tice.k-int.com
Apologies if this is a trivial problem I just cant see how to get the info.
I am traversing a schema and I have got to the point where I have my XSD
model group. I am using the model group getContents() to traverse the
elements all working okay schema analysis working. However I also need to
know what each choice or sequence has as it min/max occurs so I can properly
understand the relative min/max occurs of the contained elements.
Any help much appreciated.
Rob Tice
Re: choice or sequence min/max occurs [message #56070 is a reply to message #56017] |
Mon, 06 December 2004 19:50  |
Thanks Ed
Problem solved
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cp2opq$osv$1@www.eclipse.org...
> Rob,
> An XSDModelGroup is reached from an XSDParticle, and that is what holds
> the min/max occurs. The same model group could be reached by multiple
> particles, as for a model group in model group definition that has a
> different min/max occurs at each point of reference. So don't expect to
> be able to work back from an element declaration or model group to the
> particle that references it, since there isn't a unique answer (although
> often it will be just the container).
info.
properly
> >Rob Tice
Re: choice or sequence min/max occurs [message #593082 is a reply to message #55964] |
Mon, 06 December 2004 18:08  |
Rob,
>Rob Tice
Re: choice or sequence min/max occurs [message #593113 is a reply to message #56017] |
Thanks Ed
Problem solved
> Rob,
info.
properly
> >Rob Tice
FUDForum. Page generated in 0.29470 seconds
