Home » Language IDEs » Java Development Tools (JDT) » JUnit failure trace: line cropped after 240 characters
JUnit failure trace: line cropped after 240 characters [message #55953] Fri, 13 June 2003 00:53 Go to next message
Originally posted by: hans.schwaebli.schwaebli.de
I read that here are the gurus, so I ask here.
The problem is the JUnit view. The failure trace is cropped if a line is
longer than 240 characters.
Of course I can copy the stack trace and paste it to the editor as a
workaround, but this is no solution to me. I also can rewrite the JUnit
tests to print the stack trace on the console instead to pass it to the
JUnit framework. This is no solution for me too.
Is there any way to enable the JUnit view to print more than 240 characters
on one line instead of cropping it?
The problem applies both to Eclipse 2.0.2 and Eclipse 2.1.
Re: JUnit failure trace: line cropped after 240 characters [message #56086 is a reply to message #55953] Fri, 13 June 2003 07:11 Go to previous messageGo to next message
I doubt that JUnit view cuts the text. Most likely this limitation comes
from the OS or SWT. I suggest to file a bug report against Platform SWT.
HTH
Dani
Re: JUnit failure trace: line cropped after 240 characters [message #56630 is a reply to message #56086] Fri, 13 June 2003 12:56 Go to previous message
Originally posted by: hans.schwaebli.schwaebli.com
I did. Its not Bug 38854.
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bccbgj$164$1@rogue.oti.com...
> Hans Schw
Previous Topic:Can't create new CVS Project in Eclipse
Next Topic:Capture Exceptions thrown from Java Process
Current Time: Sun Jul 13 06:39:58 EDT 2025
Powered by FUDForum. Page generated in 0.04436 seconds
