Gantt -> Java 5.0? [message #55940] |
Sun, 13 July 2008 16:58  |
I was wondering if anyone has any major objections for the Gantt chart to
move to use Java 5.
I'm getting really tired of all the object casting I do to make it conform
to 1.4, which is not only error prone but slow, and there's quite a lot of
useful other Java 5 features I'd like to bring in. I really don't have a
clue how many use the Gantt chart apart from a few emails here and there and
what peoples requirements are as far as Java versions go. It seems at this
point most have moved to Java 5. But before I do anything drastic I thought
I'd check and see. I recall Nebula builds breaking under 5.0 or something,
but how long are we going to live under 1.4, at some point we got to move
on, right?
Feel free to chime in even if you don't use the widget. The other widgets I
don't mind leaving at 1.4 as the size of the code is considerably smaller.
Emil
Nebula Committer
http://www.hexapixel.com/
Re: Gantt -> Java 5.0? [message #58433 is a reply to message #55940] |
Thu, 28 August 2008 11:19  |
Wouldn't that make it harder to comply with Eclipse 3.3/3.4?
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_4.html
.... as long as Eclipse states a vast compatibility with Java 1.4?
For instance we are using the Gantt chart within a RCP application and due to
third library constraints we could have moved to Java 5 just a couple of months
ago.
Alex
Emil Crumhorn schrieb am 13.07.2008 22:58:
> move to use Java 5.
> on, right?
> Emil
Re: Gantt -> Java 5.0? [message #591083 is a reply to message #55940] |
Mon, 14 July 2008 06:57  |
+1 for moving to java 5 !
> move to use Java 5.
> on, right?
> Emil
Re: Gantt -> Java 5.0? [message #591965 is a reply to message #55940] |
ago.
Alex
> move to use Java 5.
> on, right?
> Emil
FUDForum. Page generated in 0.04394 seconds
