Re: Xtext Building [message #558164 is a reply to message #556532] |
Fri, 10 September 2010 11:44 |
Moritz Eysholdt Messages: 161 Registered: July 2009 Location: Kiel, Germany |
Hi Alexandre,
nope, that is not normal. However, a full build will occur, if
- you close+open a project.
- Eclipse had an unclean shutdown. Xtext's index is only persisted to
dies if Eclipse shuts down correctly. If there is no persisted
index, a full build is needed to rebuild the index.
cheers,
Moritz
> Is it normal that if I build my project entirely and shutdown Eclipse,
> then when restarting Eclipse it goes through the entire building again?
> Because a building takes about 20 minutes in my case, I would like to
> know if there is a way to avoid that and keeping the building history.
> Alexandre
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
FUDForum. Page generated in 0.03109 seconds
