Home » Archived » EPF » License question
License question [message #55938] Sat, 07 March 2009 10:50 Go to next message
Hi!
I am planing to use the OpenUP-process developing a commercial product. As
following a process should by no means be considered as a derivate work,
usage of the document templates probably should.
If this is the case one need to make own templates, though will that then
be considered a derivate work and getting me nowhere?
This ends up in the question, how can I use OpenUP to produce a commercial
product, or can't I?
Erik
Re: License question [message #56201 is a reply to message #55938] Wed, 18 March 2009 11:49 Go to previous message
Erik,
If I understand correctly, you want to adopt OpenUP as the process in your
organization/team in a project that has the objective of developing a
commercial product, correct?
If that is the case, then you can not only follow OpenUP guidance, but also
use all available templates to document your project artifacts without
restrictions.
If you were creating a process extension to OpenUP and selling the result
commercially, then restrictions would apply. However you would still be able
to create an extension plug-in to OpenUP and sell your extension plug-in. In
this case your "packaging" would contain commercial license (your plu-in)
and open source license (for OpenUP), which I understand is acceptable.
Please consult the Eclipse Public License to validate those points if
needed:
http://www.eclipse.org/legal/epl-v10.html
Ricardo.
"Erik" <paddlaren@gmail.com> wrote in message
news:ba47195430c210ecf6de8f052ed375b7$1@www.eclipse.org...
> Hi!
> Erik
Re: License question [message #591512 is a reply to message #55938] Wed, 18 March 2009 11:49 Go to previous message
Erik,
restrictions.
needed:
Ricardo.
> Hi!
> Erik
Previous Topic:EPF Composer X EPF Wiki
Next Topic:Problem to install wiki
Current Time: Tue Jul 22 08:27:43 EDT 2025
Powered by FUDForum. Page generated in 0.06754 seconds
