Home » Modeling » M2T (model-to-text transformation) » [MTL] UML primitive type problems
[MTL] UML primitive type problems [message #55910] Thu, 22 January 2009 08:36 Go to next message
I am using MTL with UML, but I ran into problems when using primitive
types from the UML standard-library. When I model attributes of a
primitive type in classes in my input-models I cannot access any
properties of that types. E.g. I cannot access the name of the primitive
types.
Since the primitive types are defined in
pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml these there are
inter-model references in my input-models. It seems that this leads to
proxy-elements in the in-memory representation (eIsProxy() returns true).
Is there a problem with MTL and proxy-elements?
Greetings,
Max
Re: [MTL] UML primitive type problems [message #55978 is a reply to message #55910] Thu, 22 January 2009 11:13 Go to previous messageGo to next message
--------------040509090604090809090209
Hi Max,
For the UML2Java example we have in MTL, we had defined our own
primitive types. We then never encountered this issue :(. As this is
most probably a bug, could you raise a bugzilla describing this issue?
Laurent Goubet
Obeo
Max Bureck a
Re: [MTL] UML primitive type problems [message #56085 is a reply to message #55978] Fri, 23 January 2009 05:44 Go to previous messageGo to next message
I just created a bug-entry for that issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=262140
For now I also use my own primitive types.
Greetings,
Max
Re: [MTL] UML primitive type problems [message #56162 is a reply to message #56085] Fri, 23 January 2009 07:17 Go to previous message
--------------020704050203060207070707
Thanks Max,
We'll try and get a look at this ASAP. This is most probably a problem
with the pathmap:// like uris :(.
laurent Goubet
Obeo
Max Bureck a
Previous Topic:JET: accessing JET variables from inline java
Next Topic:generating java code out of uml activity diagrams with Xpand2
Current Time: Tue Jul 22 13:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.04226 seconds
