Home » Archived » Visual Editor (VE) » Attaching source to swt.jar inside the SWT Container
Attaching source to swt.jar inside the SWT Container [message #55906] Fri, 13 August 2004 03:25 Go to next message
Originally posted by: harri.mindless.com
It seems that I am unable to find a way to attach source to swt.jar when
it is inside the SWT Container.
The obvious way of opening project properties -> Java build path ->
Libraries -> SWT Container -> swt.jar -> Source Attachment does not work
for me (the source attachment always disappears after pressing OK).
Editing the properties of swt.jar on the package explorer -view suggests
that I cannot attach the source directly, instead I should "go directly
to the corresponding configuration page", which I cannot find.
The bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=60614
suggests that there is no obvious way of doing this. Is there a
non-obvious way?
Re: Attaching source to swt.jar inside the SWT Container [message #55987 is a reply to message #55906] Fri, 13 August 2004 07:12 Go to previous messageGo to next message
Harry wrote:
> Hello,
> non-obvious way?
Hi Harry,
The automatic attachment of source to the SWT/JFace libraries feature
has been added in recent builds of the VE, post M2. If you try out the
VE build I20040811 it should be in there. The bug you quoted should be
updated to say this feature has been added.
- Jeff
Re: Attaching source to swt.jar inside the SWT Container [message #56068 is a reply to message #55987] Fri, 13 August 2004 10:18 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Actually it was fixed in M2. :-) It was
https://bugs.eclipse.org/bugs/show_bug.cgi?id=70782.
Thanks, Rich Kulp
Re: Attaching source to swt.jar inside the SWT Container [message #597293 is a reply to message #55906] Fri, 13 August 2004 07:12 Go to previous message
Harry wrote:
> Hello,
> non-obvious way?
Hi Harry,
- Jeff
Re: Attaching source to swt.jar inside the SWT Container [message #597314 is a reply to message #55987] Fri, 13 August 2004 10:18 Go to previous message
Thanks, Rich Kulp
Previous Topic:VE shows "IWAV0170I Connection creation failed" when trying to load/show a frame
Next Topic:Adding 3rd party beans to VE
Current Time: Sat Aug 02 04:33:42 EDT 2025
Powered by FUDForum. Page generated in 0.03550 seconds
