Home » Language IDEs » ServerTools (WTP) » Call for WTP M2 Feedback
Re: Call for WTP M2 Feedback [message #56040 is a reply to message #55986] |
Tue, 14 December 2004 21:53   |
Originally posted by: varavamu.yahoo.com
hi David,
but if we test this with Eclipse M3 - how are you going to get feedback on
whether this works with M4? According to the milestone plan, the latest I-builds
should work with Eclipse M4, correct?
thanks,
Vijay
David Williams wrote:
> On Tue, 14 Dec 2004 22:31:34 +0000, snpe <snpe@snpe.co.yu> wrote:
> Wow ... feedback already :)
> Basically you should test most recent I-build, on Eclipse M3, and all
> the prereqs
> listed on build page.
> I've updated the milestone plan with some links to the component
> test plans and mini-test-tutorials. The tutorial in particular has
> the steps for getting things installed and running with server, etc.
> Milestone Plan:
> http://eclipse.org/webtools/development/planning/milestone_p lan_1_0.html
> Example Test Tutorial:
> http://eclipse.org/webtools/testtutorials/M2/tutorial1/wtp-t utorial-I.html
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56067 is a reply to message #56040] |
Tue, 14 December 2004 22:18   |
Eclipse M4 does not come out until at least the end of this week
Darins
"Vijay Aravamudhan" <varavamu@yahoo.com> wrote in message
news:cpo8vd$bvb$1@www.eclipse.org...
> hi David,
> I-builds should work with Eclipse M4, correct?
> thanks,
> Vijay
>> Basically you should test most recent I-build, on Eclipse M3, and all the
>> prereqs
>> Milestone Plan:
>> Hope this helps,
Re: Call for WTP M2 Feedback [message #56094 is a reply to message #55904] |
Wed, 15 December 2004 03:36   |
Arthur,
Arthur Ryman schrieb:
> We are planning to release the WTP M2 milestone on Dec. 22 and would
> like to get your feedback on its readiness. Please test the latest
> builds and assess the functions that are advertised in our milestone
> plan for M2.[1] If you find problems, please open Bugzilla defects. Our
> M2 exit criteria is that the High priority items work. Thx.
Is there some kind of quick-start guide available (eg. how to start from
scratch, what are the project types, how do they fit together)?
I would classify myself as WTP beginner that organized his J2EE projects
in tha past in a complete different way than the WTP does. Whenever I
try something on the WTP I'm hit by "beginner" issues. For example, last
time I defined a Tomcat 5.5 server in the preferences and then invoked a
wizard to create a new web project (just for trying something). However,
I never got the server to pop up in the combo provided in the wizard,
until I discovered, that the wizard is expecting a J2EE server (not a
Tomcat server) although I just wanted to create a simple "web" project
with some servlets and JSPs etc.
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56147 is a reply to message #55986] |
Wed, 15 December 2004 18:32   |
David,
Is there instructions for build from cvs - I can't download
all requierments every times - I build eclipse from cvs easy
emf,gef and vep isn't to big for download, but webtools and eclipse are big
problem for me is only : build webtools from cvs (i have webtools cvs tree)
> prereqs listed on build page.
> Milestone Plan:
> Hope this helps,
Re: Call for WTP M2 Feedback [message #57403 is a reply to message #55904] |
Thu, 23 December 2004 04:32  |
Originally posted by: gael.billard.jwaretechnologies.com
There a setting for HTML editor to specify wether to use uppercase or
lowercase tag. Such settings should be shared (or make this setting
available) with other editor like JSP (html part).
> [1]
> -- Arthur Ryman
Current Time: Sat Jul 12 20:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.08653 seconds
