Home » Language IDEs » ServerTools (WTP) » Call for WTP M2 Feedback
Call for WTP M2 Feedback [message #55904] Tue, 14 December 2004 08:56 Go to next message
We are planning to release the WTP M2 milestone on Dec. 22 and would
like to get your feedback on its readiness. Please test the latest
builds and assess the functions that are advertised in our milestone
plan for M2.[1] If you find problems, please open Bugzilla defects. Our
M2 exit criteria is that the High priority items work. Thx.
[1] http://eclipse.org/webtools/development/planning/milestone_p lan_1_0.html
-- Arthur Ryman
Re: Call for WTP M2 Feedback [message #55937 is a reply to message #55904] Tue, 14 December 2004 13:50 Go to previous messageGo to next message
> [1]
> -- Arthur Ryman
How do we test it? Using the latest nightly of Eclipse 3.1 M4 or the M3
release?
Re: Call for WTP M2 Feedback [message #55961 is a reply to message #55904] Tue, 14 December 2004 17:31 Go to previous messageGo to next message
I would like test it, but is there manual for requirments and install from
cvs
regards
Haris Peco
> [1]
> [ http://eclipse.org/webtools/development/planning/milestone_p lan_1_0.html
> -- Arthur Ryman
Re: Call for WTP M2 Feedback [message #55986 is a reply to message #55961] Tue, 14 December 2004 19:54 Go to previous messageGo to next message
On Tue, 14 Dec 2004 22:31:34 +0000, snpe <snpe@snpe.co.yu> wrote:
Wow ... feedback already :)
Basically you should test most recent I-build, on Eclipse M3, and all the prereqs
listed on build page.
I've updated the milestone plan with some links to the component
test plans and mini-test-tutorials. The tutorial in particular has
the steps for getting things installed and running with server, etc.
Milestone Plan:
Example Test Tutorial:
http://eclipse.org/webtools/testtutorials/M2/tutorial1/wtp-t utorial-I.html
Hope this helps,
Re: Call for WTP M2 Feedback [message #56040 is a reply to message #55986] Tue, 14 December 2004 21:53 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
hi David,
but if we test this with Eclipse M3 - how are you going to get feedback on
whether this works with M4? According to the milestone plan, the latest I-builds
should work with Eclipse M4, correct?
thanks,
Vijay
> the prereqs
> Milestone Plan:
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56067 is a reply to message #56040] Tue, 14 December 2004 22:18 Go to previous messageGo to next message
Eclipse M4 does not come out until at least the end of this week
Darins
"Vijay Aravamudhan" <varavamu@yahoo.com> wrote in message
news:cpo8vd$bvb$1@www.eclipse.org...
> hi David,
> I-builds should work with Eclipse M4, correct?
> thanks,
> Vijay
>> prereqs
>> Milestone Plan:
>> Hope this helps,
Re: Call for WTP M2 Feedback [message #56094 is a reply to message #55904] Wed, 15 December 2004 03:36 Go to previous messageGo to next message
Arthur,
Is there some kind of quick-start guide available (eg. how to start from
scratch, what are the project types, how do they fit together)?
I would classify myself as WTP beginner that organized his J2EE projects
in tha past in a complete different way than the WTP does. Whenever I
try something on the WTP I'm hit by "beginner" issues. For example, last
time I defined a Tomcat 5.5 server in the preferences and then invoked a
wizard to create a new web project (just for trying something). However,
I never got the server to pop up in the combo provided in the wizard,
until I discovered, that the wizard is expecting a J2EE server (not a
Tomcat server) although I just wanted to create a simple "web" project
with some servlets and JSPs etc.
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56121 is a reply to message #56040] Wed, 15 December 2004 09:35 Go to previous messageGo to next message
On Tue, 14 Dec 2004 18:53:34 -0800, Vijay Aravamudhan <varavamu@yahoo.com> wrote:
> hi David,
> thanks,
> Vijay
Yes ... we are still building with M3 until M4 is officially released on 17th. If all
goes smoothly, we'll just upgrade to M4 and 17th or 18th and
do a little sanity checking with that build to be sure is still ok. If not ok, we'll
at least know how we stand using M3.
Re: Call for WTP M2 Feedback [message #56147 is a reply to message #55986] Wed, 15 December 2004 18:32 Go to previous messageGo to next message
David,
Is there instructions for build from cvs - I can't download
all requierments every times - I build eclipse from cvs easy
emf,gef and vep isn't to big for download, but webtools and eclipse are big
problem for me is only : build webtools from cvs (i have webtools cvs tree)
> prereqs listed on build page.
> Milestone Plan:
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56191 is a reply to message #56147] Wed, 15 December 2004 22:32 Go to previous messageGo to next message
On Wed, 15 Dec 2004 23:32:09 +0000, snpe <snpe@snpe.co.yu> wrote:
> David,
Can you read my posting earlier in this news group
(See news:opshvtn1gxac05ss@news.eclipse.org,
and see if that helps?
It discusses using PDE targets and the Eclipse releng tool to "load map projects".
That summarizes how I do it anyway ... if that post doesn't get at what you are asking,
please re-post.
See <A TITLE="Loading I builds"
HREF="news:opshvtn1gxac05ss@news.eclipse.org">Loading I Builds</A>
Re: Call for WTP M2 Feedback [message #56211 is a reply to message #55986] Thu, 16 December 2004 03:12 Go to previous messageGo to next message
Originally posted by: kalle.stenflo.exallon.sigma.se
Hi David,
I have experienced some problems adding and running a Tomcat 5.5 server.
When using the default name creating the server "Tomcat v5.5 Server @
127.0.0.1" I was propmted with a deployment error. When I removed the blanks
from the name "Tomcatv5.5Server@127.0.0.1" it worked fine.
Thank you
/Kalle
"David Williams" <david_williams@us.ibm.com> wrote in message
news:opsi0x4abiac05ss@news.eclipse.org...
prereqs
> Milestone Plan:
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56229 is a reply to message #56211] Thu, 16 December 2004 09:16 Go to previous messageGo to next message
Added bug to bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=81394
/Kalle
"kalle stenflo" <kalle.stenflo@exallon.sigma.se> wrote in message
news:cprg0t$348$1@www.eclipse.org...
> Hi David,
blanks
> Thank you
> /Kalle
the
> prereqs
> > Milestone Plan:
> > Hope this helps,
Re: Call for WTP M2 Feedback [message #56246 is a reply to message #55904] Thu, 16 December 2004 11:38 Go to previous messageGo to next message
Originally posted by: unknown.nodomain.com
are there any plans for relative simple installation? I find it complicated
to install 5-6 different components. For example when I download eclipse I
don't have to download the xml parser, tomcat, ant etc. separately.
Zsolt
"Arthur Ryman" <ryman@ca.ibm.com> schrieb im Newsbeitrag
news:cpmrdl$n8$1@www.eclipse.org...
> We are planning to release the WTP M2 milestone on Dec. 22 and would like
> to get your feedback on its readiness. Please test the latest builds and
> assess the functions that are advertised in our milestone plan for M2.[1]
> If you find problems, please open Bugzilla defects. Our M2 exit criteria
> [1]
> -- Arthur Ryman
Re: Call for WTP M2 Feedback [message #56261 is a reply to message #56246] Thu, 16 December 2004 12:25 Go to previous messageGo to next message
On Thu, 16 Dec 2004 17:38:10 +0100, Zsolt <unknown@nodomain.com> wrote:
> Zsolt
Eventually we will make use of Eclipse's update manager.
We are still pretty early in development, and we know everyone giving it
a try are on the "bleeding edge" ... so, thanks for the efforts.
Re: Call for WTP M2 Feedback [message #56308 is a reply to message #56261] Thu, 16 December 2004 12:38 Go to previous messageGo to next message
That is the best solution I think.
Zsolt
Re: Call for WTP M2 Feedback [message #56333 is a reply to message #56191] Thu, 16 December 2004 17:18 Go to previous messageGo to next message
>> David,
>> big problem for me is only : build webtools from cvs (i have webtools cvs
>> tree)
> projects". That summarizes how I do it anyway ... if that post doesn't get
> at what you are asking, please re-post.
I don't understand eclipse building proces - I will check cruise.xml and
try build with ant
I have last eclipse cvs, ve 1.0.2
Is it last build gef and emf (full sdk) enough ?
Re: Call for WTP M2 Feedback [message #56690 is a reply to message #55904] Mon, 20 December 2004 02:39 Go to previous messageGo to next message
The release seems to work fine but makes the UI somewhat unresponsive. I
guess a lot operations are executed in the UI thread. Example: save of a
simple web.xml takes 4 seconds. Save of a simple Java class takes up to
10 seconds. Same workspace but without WTP plugins runs much faster.
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56717 is a reply to message #56690] Mon, 20 December 2004 02:52 Go to previous messageGo to next message
Another example:
- Open the Server view
- right click on server
- select "Add or remove projects..."
=> takes 24 seconds till the dialog is open!
note that I only have two projects in the workspace (one from the WTP
tutorial any my own project). Only the WTP tutorial project contains a
Java class. The other project is a J2EE Web Project two but containes
only a directory "contribution" with a few zips and their extracted
content (around 1600 files).
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56771 is a reply to message #56717] Mon, 20 December 2004 11:03 Go to previous messageGo to next message
Gunnar,
Thanks for the performance feedback. Please open Bugzillas at [1] for
each of these problems. Try to select the most appropriate component.
For example, the web.xml problem is probably in the jst.j2ee component.
We are taking performance very seriously in this project. Jeffrey Liu is
our dedicated WTP performance analyst and he has a lot of experience
diagnosing these problems.
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols
Re: Call for WTP M2 Feedback [message #56823 is a reply to message #55904] Mon, 20 December 2004 11:29 Go to previous messageGo to next message
Originally posted by: daagar.gmail.com
With the current release (I20041218) with Eclipse 3.1M4 and the prereqs
listed, I'm no longer able to launch a Tomcat 5.0 server. I get 'failed to
publish' errors with a 'null' server config. With the WTP in such flux
because of the upcoming milestone and the very recent 3.1M4 release, I'm
not submitting a bugzilla bug yet, just wanted to point it out.
Re: Call for WTP M2 Feedback [message #56848 is a reply to message #56823] Mon, 20 December 2004 11:42 Go to previous messageGo to next message
Changing the server name to contain no spaces solved the issue (I
forgot that someone had already posted this issue). Everything else seems
to work slick.
Re: Call for WTP M2 Feedback [message #56956 is a reply to message #56848] Tue, 21 December 2004 05:17 Go to previous messageGo to next message
> to work slick.
I had the same errors, and by removing the spaces worked.
Re: Call for WTP M2 Feedback [message #57245 is a reply to message #56956] Wed, 22 December 2004 11:47 Go to previous messageGo to next message
Originally posted by: leetree1.yahoo.com
Srgjan Srepfler wrote:
> daagar wrote:
>>> prereqs listed, I'm no longer able to launch a Tomcat 5.0 server. I
>>> get 'failed to publish' errors with a 'null' server config. With the
>>> WTP in such flux because of the upcoming milestone and the very
>>> recent 3.1M4 release, I'm not submitting a bugzilla bug yet, just
>> seems to work slick.
Where do I get the downloads for this? I used to know :-) but forgot.
Re: Call for WTP M2 Feedback [message #57273 is a reply to message #57245] Wed, 22 December 2004 11:54 Go to previous messageGo to next message
Suprisingly here:
http://www.eclipse.org/webtools/downloads.html
You'll want the latest I-build.. But the thing with the spaces hasn't been
fixed (yet) in the Wed, 22 Dec 2004 -- 06:58 (-0500) build.
Re: Call for WTP M2 Feedback [message #57403 is a reply to message #55904] Thu, 23 December 2004 04:32 Go to previous message
Originally posted by: gael.billard.jwaretechnologies.com
There a setting for HTML editor to specify wether to use uppercase or
lowercase tag. Such settings should be shared (or make this setting
available) with other editor like JSP (html part).
> [1]
> -- Arthur Ryman
Previous Topic:Binding a CM ModelQuery to a filename extension?
Next Topic:Problem with JSP Source Page Editor / code assist
Current Time: Mon Jul 21 21:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.29199 seconds
