Home » Eclipse Projects » Remote Application Platform (RAP) » Registry conflict (running org.eclipse.equinox.jsp.jasper.registry)
Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #55817] Fri, 26 October 2007 07:08 Go to next message
Originally posted by: dp-conde.criticalsoftware.com
I need to run org.eclipse.help.webapp package (as well as some other
packages) to have an embedded eclipse help system in my application.
The problem here is that this package has a dependency of one other
package (org.eclipse.equinox.jsp.jasper.registry) that conflicts with
some other packages that I need for the application.
So I was wondering, is it possible to run org.eclipse.help.webapp
without org.eclipse.equinox.jsp.jasper.registry? I'm using maven to
compile my project and I tried changing the dependencies on the pom.xml
file like this:
<dependency>
<groupId>org.eclipse.help</groupId>
<artifactId>webapp</artifactId>
<version>3.3.0</version>
<exclusions>
<exclusion>
<groupId>org.eclipse.equinox.jsp.jasper</groupId>
<artifactId>registry</artifactId>
</exclusion>
</exclusions>
</dependency>
But this didn't work, any thoughts about this issue?
Thanks in advance,
Daniel Conde.
Re: Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #57547 is a reply to message #55817] Mon, 05 November 2007 04:36 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I guess you mean bundle-dependencies - not package dependencies. As the
dependency to org.eclipse.equinox.jsp.jasper.registry is defined in the
Required-Bundle header of the plug-in's manifest there is nothing you can do
about that without hacking the the webapp bundle - which I do not recommend.
Of what kind are those conflicts you have mentionend?
Ciao
Frank
"Daniel Conde" <dp-conde@criticalsoftware.com> schrieb im Newsbeitrag
news:ffshv1$7rq$2@build.eclipse.org...
> Hello,
> So I was wondering, is it possible to run org.eclipse.help.webapp without
> org.eclipse.equinox.jsp.jasper.registry? I'm using maven to compile my
> project and I tried changing the dependencies on the pom.xml file like
> this:
> <dependency>
> <exclusions>
> <exclusion>
> </exclusion>
> </exclusions>
> </dependency>
> Thanks in advance,
> Daniel Conde.
Re: Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #58411 is a reply to message #57547] Wed, 07 November 2007 12:08 Go to previous messageGo to next message
Hi Frank,
The conflict I mentioned was that with the
org.eclipse.equinox.jsp.jasper.registry running for the webapp, the
application doesn't load any images...
Any thoughts about this?
Thanks in advance.
Frank Appel wrote:
> Ciao
> Frank
>> Hello,
>> this:
>> <dependency>
>> <exclusions>
>> <exclusion>
>> </exclusion>
>> </exclusions>
>> </dependency>
>> Thanks in advance,
>> Daniel Conde.
Re: Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #59566 is a reply to message #58411] Wed, 14 November 2007 04:11 Go to previous message
I think I still do not grasp it. Using the help system, I integrated the
org.eclipse.help.webapp package (including the jasper registry dependency)
without any problem. Seems as every image in the application gets loaded as
expected. So maybe the problem is something different?
Ciao
Frank
news:fgsrfm$d3n$1@build.eclipse.org...
> Hi Frank,
> Thanks in advance.
> Frank Appel wrote:
>> do about that without hacking the the webapp bundle - which I do not
>> recommend. Of what kind are those conflicts you have mentionend?
>> Ciao
>> Frank
>>> Hello,
>>> file like this:
>>> <dependency>
>>> <exclusions>
>>> <exclusion>
>>> </exclusion>
>>> </exclusions>
>>> </dependency>
>>> Thanks in advance,
>>> Daniel Conde.
Previous Topic:problem with custom widget
Next Topic:Deny access to one TabItem in a TabFolder
Current Time: Wed Jul 30 15:54:15 EDT 2025
Powered by FUDForum. Page generated in 0.04367 seconds
