info on running HTTP Service? [message #55812] |
Thu, 05 January 2006 11:25  |
Originally posted by: yoduderoo.netscape.net
I am getting started with equinox. I started the console using the info
in the "Getting Started" doc.
I connect to the Eclipse CVS and imported the HTTP Service. From
Eclipse, I exported it as a jar and then installed manually using the
console "install" and "start" commands. "Status" shows it is ACTIVE. But
now what?
It looks to me like a tomcat is expected....
Is there any info available to help a newbie like me in getting the http
service running?
y
Re: info on running HTTP Service? [message #61445 is a reply to message #61299] |
Mon, 13 February 2006 06:39  |
Originally posted by: morova.bol.com.br
It worked, thanks! On Eclipse 3.2M4, it worked using -D argument under
Arguments tab, but not using Environment tab in Run dialog. Should I post
a bug for this?
Gustavo
On Fri, 10 Feb 2006 21:26:51 +0000, Simon Kaegi wrote:
> Hi Gustavo,
> Setting "org.osgi.service.http.port" (e.g. -Dxxx or as a System property)
> to a value other than 80 is supported for the Equinox HttpService.
> -Simon
FUDForum. Page generated in 0.04446 seconds
