Home » Modeling » GMF (Graphical Modeling Framework) » GMF Modelling Beginner question
GMF Modelling Beginner question [message #55786] Tue, 26 September 2006 09:06 Go to next message
Originally posted by: achitre.megawareinc.com
I have just started looking at GMF and have succesfully copleted the
Mindmap tutorial. Now I am trying to create my own model by defining a
simple schema. The schema has a top level element PurchaseOrder which
contains a collection of Item elements, as shown below.
<?xml version="1.0" encoding="utf-8" ?>
<xs:schema targetNamespace="http://www.poexample.com/gmf/poexample"
elementFormDefault="qualified"
xmlns:po="http://www.poexample.com/gmf/poexample"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<xs:element name="purchaseorder" type="po:PurchaseOrder"/>
<xs:complexType name="PurchaseOrder">
<xs:sequence minOccurs="1" maxOccurs="1">
<xs:element name="items"
type="po:Item" minOccurs="1" maxOccurs="unbounded"
ecore:reference="po:Item"/>
</xs:sequence>
<xs:attribute name="id" type="xs:string" />
<xs:attribute name="shippingAddress" type="xs:string" />
<xs:attribute name="billingAddress" type="xs:string" />
</xs:complexType>
<xs:complexType name="Item" ecore:reference="po:PurchaseOrder">
<xs:attribute name="name" type="xs:string" />
<xs:attribute name="quantity" type="xs:string" />
<xs:attribute name="price" type="xs:float" />
</xs:complexType>
</xs:schema>
I created a new EMF Model from the XSD, then generate the model code and the
Edit Code. After that when I create .gmfgraph, in the Graphical Definition
dialog I can only see DocumentRoot, Item, and PurchaseOrder. There are no
attributes under Item. Continuing further when I generate the diagram code I
get the following error.
The method setnull(DocumentRoot) is undefined for the type DocumentRoot.
Thanks & Regards,
Aniruddh
Re: GMF Modelling Beginner question [message #56029 is a reply to message #55786] Tue, 26 September 2006 13:44 Go to previous messageGo to next message
You need either choose PurchaseOrder as a top item or introduce another
container, e.g. Orders. DocumentRoot can't be used as an element of domain
model
Artem
"Aniuddh Chitre" <achitre@megawareinc.com> wrote in message
news:efb8kc$epd$1@utils.eclipse.org...
> </xs:sequence>
> </xs:complexType>
> </xs:complexType>
> </xs:schema>
> the Edit Code. After that when I create .gmfgraph, in the Graphical
> Definition dialog I can only see DocumentRoot, Item, and PurchaseOrder.
> There are no attributes under Item. Continuing further when I generate the
> diagram code I get the following error.
> Thanks & Regards,
> Aniruddh
Re: GMF Modelling Beginner question [message #56269 is a reply to message #56029] Wed, 27 September 2006 08:58 Go to previous messageGo to next message
I have modified the schema as follows.
<xsd:schema targetNamespace="http://www.poexample.com/gmf/poexample"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
<xsd:element name="purchaseorder" type="po:Orders" />
<xsd:complexType name="Orders">
<xsd:sequence>
<xsd:element name="purchaseorders" type="po:PurchaseOrder"
maxOccurs="unbounded" minOccurs="0">
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="PurchaseOrder">
<xsd:sequence minOccurs="1" maxOccurs="1">
<xsd:element name="items" type="po:Item" minOccurs="1"
maxOccurs="unbounded" />
</xsd:sequence>
<xsd:attribute name="id" type="xsd:string" />
<xsd:attribute name="shippingAddress" type="xsd:string" />
<xsd:attribute name="billingAddress" type="xsd:string" />
</xsd:complexType>
<xsd:complexType name="Item">
<xsd:attribute name="name" type="xsd:string" />
<xsd:attribute name="quantity" type="xsd:string" />
<xsd:attribute name="price" type="xsd:float" />
</xsd:complexType>
</xsd:schema>
When I generate the gmfgraph and select Orders as the Diagram Element it
does not show any links. A screen shot of the Graphical Definiton dialog is
attached.
Aniruddh
"Artem Tikhomirov" <artem.tikhomirov@borland.com> wrote in message
news:efbooj$h6h$1@utils.eclipse.org...
> model
> Artem
>> </xs:sequence>
>> </xs:complexType>
>> </xs:complexType>
>> </xs:schema>
>> the
>> Thanks & Regards,
>> Aniruddh
Re: GMF Modelling Beginner question [message #56426 is a reply to message #56269] Wed, 27 September 2006 12:49 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
References were not recognized as links since they are containments; I
could suggest to use GMF 2.0 or simply add link figures and tools by
hand (I mean using editors generated by EMF).
Aniuddh Chitre wrote:
> <xsd:sequence>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:complexType>
> </xsd:schema>
> attached.
> Aniruddh
>> model
>> Artem
>>> Hi,
>>> </xs:sequence>
>>> </xs:complexType>
>>> </xs:complexType>
>>> </xs:schema>
>>> the
>>> Thanks & Regards,
>>> Aniruddh
Re: GMF Modelling Beginner question [message #57478 is a reply to message #56426] Fri, 29 September 2006 07:47 Go to previous messageGo to next message
I added a Ployline Connection, a Connection, and a Compartment in the
..gmfgraph. Now when I create the generator model it gives me an error saying
that the targetmetafeature has not been set. I saw a a similar problem
reported in this group. In my gmfmaps link mapping the Target Feature is
empty. What should it be set to? In the mindmap example the Target Feature
shows EReference's in the model. In my case its only showing the attributes.
A screen shot is attached. Can someone tell me the significance of this
property and how to make sure that it has the proper value.
Thanks & Regards,
Aniruddh
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:efea35$jr9$1@utils.eclipse.org...
>> <xsd:sequence>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:complexType>
>> </xsd:schema>
>> is
>> attached.
>> Regards,
>> Aniruddh
>>> domain
>>> model
>>> Artem
>>>> Hi,
>>>> </xs:sequence>
>>>> </xs:complexType>
>>>> </xs:complexType>
>>>> </xs:schema>
>>>> and
>>>> the
>>>> DocumentRoot.
>>>> Thanks & Regards,
>>>> Aniruddh
Re: GMF Modelling Beginner question [message #57581 is a reply to message #57478] Fri, 29 September 2006 09:00 Go to previous messageGo to next message
Your screenshot shows you are trying to use Item as a link (often referred
to "link as class"). What you need to do is to have another top level node
mapping for item, and for the link mapping, leave containment and element
fields blank and put 'items' reference as target metafeature.
Artem
news:efj14p$g6h$1@utils.eclipse.org...
> saying that the targetmetafeature has not been set. I saw a a similar
> problem reported in this group. In my gmfmaps link mapping the Target
> Feature is empty. What should it be set to? In the mindmap example the
> Target Feature shows EReference's in the model. In my case its only
> showing the attributes. A screen shot is attached. Can someone tell me the
> significance of this property and how to make sure that it has the proper
> value.
> Thanks & Regards,
> Aniruddh
>>> Hi,
>>> <xsd:sequence>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> is
>>> attached.
>>> Regards,
>>> Aniruddh
>>>> domain
>>>> model
>>>> Artem
>>>>> Hi,
>>>>> </xs:sequence>
>>>>> </xs:complexType>
>>>>> </xs:complexType>
>>>>> </xs:schema>
>>>>> and
>>>>> PurchaseOrder.
>>>>> the
>>>>> DocumentRoot.
>>>>> Thanks & Regards,
>>>>> Aniruddh
Re: GMF Modelling Beginner question [message #58635 is a reply to message #57581] Tue, 03 October 2006 07:47 Go to previous messageGo to next message
I am not sure how to have a top level node mapping for item. Do I need to
do this in the ecore model or in the gmfgraph.
Thanks & Regards,
Aniruddh
news:efj57b$7p8$1@utils.eclipse.org...
> Artem
>> the significance of this property and how to make sure that it has the
>> proper value.
>> Thanks & Regards,
>> Aniruddh
>>>> Hi,
>>>> <xsd:sequence>
>>>> </xsd:element>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> </xsd:complexType>
>>>> </xsd:schema>
>>>> it
>>>> dialog is
>>>> attached.
>>>> Regards,
>>>> Aniruddh
>>>>> another
>>>>> domain
>>>>> model
>>>>> Artem
>>>>>> Hi,
>>>>>> the
>>>>>> a
>>>>>> </xs:sequence>
>>>>>> </xs:complexType>
>>>>>> </xs:complexType>
>>>>>> </xs:schema>
>>>>>> and
>>>>>> PurchaseOrder.
>>>>>> generate
>>>>>> the
>>>>>> DocumentRoot.
>>>>>> Thanks & Regards,
>>>>>> Aniruddh
Re: GMF Modelling Beginner question [message #59469 is a reply to message #58635] Thu, 05 October 2006 08:14 Go to previous message
You've got top level node for the 'PurchaseOrder', and I suggested to have
similar one for 'Item' domain element. We are talking about changes to
..gmfmap file, which is the model that actually describes what's link and
what's node in your domain.
Artem
news:eftijp$7aq$1@utils.eclipse.org...
> to do this in the ecore model or in the gmfgraph.
> Thanks & Regards,
> Aniruddh
>> referred to "link as class"). What you need to do is to have another top
>> level node mapping for item, and for the link mapping, leave containment
>> and element fields blank and put 'items' reference as target metafeature.
>> Artem
>>> Hi,
>>> proper value.
>>> Thanks & Regards,
>>> Aniruddh
>>>>> Hi,
>>>>> <xsd:sequence>
>>>>> </xsd:element>
>>>>> </xsd:sequence>
>>>>> </xsd:complexType>
>>>>> </xsd:sequence>
>>>>> </xsd:complexType>
>>>>> </xsd:complexType>
>>>>> </xsd:schema>
>>>>> it
>>>>> dialog is
>>>>> attached.
>>>>> Regards,
>>>>> Aniruddh
>>>>>> another
>>>>>> domain
>>>>>> model
>>>>>> Artem
>>>>>>> Hi,
>>>>>>> the
>>>>>>> a
>>>>>>> which
>>>>>>> </xs:sequence>
>>>>>>> </xs:complexType>
>>>>>>> </xs:complexType>
>>>>>>> </xs:schema>
>>>>>>> and
>>>>>>> PurchaseOrder.
>>>>>>> generate
>>>>>>> the
>>>>>>> DocumentRoot.
>>>>>>> Thanks & Regards,
>>>>>>> Aniruddh
Previous Topic:Popup Menu / Image / Compartment
Next Topic:Link appearance
Current Time: Wed Jul 30 15:56:25 EDT 2025
Powered by FUDForum. Page generated in 0.05176 seconds
