Home » Modeling » M2T (model-to-text transformation) » JET: accessing JET variables from inline java
JET: accessing JET variables from inline java [message #55768] Tue, 20 January 2009 14:46 Go to next message
Originally posted by: johannes.nel.gmail.com
Hi all
In a JET template is there a way for me to access xpath variables from
inline Java.
<c:setVariable var="path" select="getPathFromPackage($curItem/@package)"/>
<% System.out.println($path); %>
thanks johan
Re: accessing JET variables from inline java [message #55854 is a reply to message #55768] Wed, 21 January 2009 11:51 Go to previous message
Johan:
There is JET2Context.getVariable:
http://help.eclipse.org/ganymede/topic/org.eclipse.jet.doc/r eferences/javadoc/org/eclipse/jet/JET2Context.html#getVariab le(java.lang.String)
The variable 'context' is predefined in your template.
But, you may find that the type of the value returned is sometimes a
NodeSet (depending on the original expression). You can use use
XPathUtil.xpathString():
http://help.eclipse.org/ganymede/topic/org.eclipse.jet.doc/r eferences/javadoc/org/eclipse/jet/xpath/XPathUtil.html#xpath String(java.lang.Object)
It will convert the result to a String:
<%@jet imports="org.eclipse.jet.xpath.XPathUtil" %>
<%= System.out.println(XPathUtil.xpathString(context.getVariable ( "path")) %>
Finally, if all you are doing is trying to inject trace statements into your
transformation, why not try the <c:log> tag:
http://help.eclipse.org/ganymede/topic/org.eclipse.jet.doc/r eferences/taglibs/controlTags/logTag.html
<c:log><c:get select="$path"/></c:log>
The tag has an optional attribute that specifies the log level. By default,
an executing JET transformation writes only info, warning and error
messages. This can be changed in the JET launch configuration.
Paul
Previous Topic:character entity in the input model gets substituted in the generated file even if it's xml/xhtml
Next Topic:[MTL] UML primitive type problems
Current Time: Sun Aug 31 04:51:55 EDT 2025
Powered by FUDForum. Page generated in 0.03143 seconds
