Home » Eclipse Projects » Remote Application Platform (RAP) » problem with custom widget
problem with custom widget [message #55736] Fri, 26 October 2007 06:56 Go to next message
Originally posted by: wen.ai.gillardon.de
I'm beginning to create a custom widget and it works. The example 'Gmap'
gives me every help indeed. Now I can pass some text to the browser and
catch it there very well, or call a function on the browser correctly
after doing something on the server.
The problem is, I don't know how can I get some texts(for example) back
from the browser and then catch them on the server side. It should be
possible, but I don't know how. If anybody has a idea, please do me a
favor. Many thanks.
Cheers
Wen
Re: problem with custom widget [message #55791 is a reply to message #55736] Fri, 26 October 2007 06:59 Go to previous messageGo to next message
Hi Wen,
I don't know if you are aware of the fact that there is a Custom widget
tutorial in the online help (or in your Eclipse installation if you used
the update site).
See
http://help.eclipse.org/help33/topic/org.eclipse.rap.help/he lp/html/advanced/custom-widget.html
The interesting part is readData in your LCA. See tutorial and GMap
widget for an example.
Hope that helps!
Greets
Benny
Wen Ai wrote:
> favor. Many thanks.
> Cheers
> Wen
Re: problem with custom widget [message #56445 is a reply to message #55791] Tue, 30 October 2007 04:39 Go to previous messageGo to next message
Hi Benny,
thanks for your help. I have tried your suggestions and have found
something interesting in GMap.js.
_onMapMove : function() {
if( !org_eclipse_rap_rwt_EventUtil_suspend ) {
var wm = org.eclipse.swt.WidgetManager.getInstance();
var gmapId = wm.findIdByWidget( this );
var center = this._map.getCenter().toString();
var req = org.eclipse.swt.Request.getInstance();
req.addParameter( gmapId + ".mapCenter", center );
In this part if I change mapCenter into centerLocation just following
the definition in java, it works fine. Could it be a bug?
Greetings.
Wen
Benjamin Muskalla schrieb:
> Hi Wen,
> the update site).
> See
> Hope that helps!
> Greets
> Benny
> Wen Ai wrote:
>> 'Gmap' gives me every help indeed. Now I can pass some text to the
>> browser and catch it there very well, or call a function on the
>> browser correctly after doing something on the server.
>> back from the browser and then catch them on the server side. It
>> should be possible, but I don't know how. If anybody has a idea,
>> please do me a favor. Many thanks.
>> Cheers
>> Wen
Re: problem with custom widget [message #56472 is a reply to message #56445] Tue, 30 October 2007 05:36 Go to previous message
Good catch Wen. Thanks for the info - I just fixed it in CVS.
Greets
Benny
Wen Ai wrote:
> Hi Benny,
> Greetings.
> Wen
>> Hi Wen,
>> widget tutorial in the online help (or in your Eclipse installation if
>> you used the update site).
>> See
>> Hope that helps!
>> Greets
>> Benny
>> Wen Ai wrote:
>>> Hi,
>>> Cheers
>>> Wen
Previous Topic:Servlet delegate not registered
Next Topic:Registry conflict (running org.eclipse.equinox.jsp.jasper.registry)
Current Time: Wed Jul 30 15:57:45 EDT 2025
Powered by FUDForum. Page generated in 0.03935 seconds
