Problem to create admin account in EPF Wiki [message #55691] |
Thu, 26 February 2009 12:54  |
--------------000504000006030303010108
I installed the EPF Wiki and I
Re: Problem to create admin account in EPF Wiki [message #55749 is a reply to message #55691] |
Tue, 03 March 2009 07:36  |
Hi all,
I disabled the e-mail and everything worked! I´ll try to enable it again
later.
Thank you,
Fernanda
Fernanda Oliveira escreveu:
> I installed the EPF Wiki and I´m havinf problems at the first step, the
> admin account creation.
> After fill the fields (name, e-mail, password), I received the attached
> message ("No such file or directory /usr/sbin/sendmail -i -t").
> Nothing happens when I click in other links in the top menu (left or
> right), and I can´t move to the next step.
> I reviewed my mail settings and changed to my gmail account:
> ActionMailer::Base.smtp_settings = {
> :address => 'smtp.gmail.com',
> :port => 465,
> :domain => 'gmail.com',
> :user_name => 'ferstring@gmail.com',
> :password => 'xxxxxx',
> :authentication => :login
> Please, do you have some clue?
> Thank you,
> Fernanda
Re: Problem to create admin account in EPF Wiki [message #591376 is a reply to message #55691] |
Hi all,
later.
Thank you,
Fernanda
> :port => 465,
> Thank you,
> Fernanda
FUDForum. Page generated in 0.17044 seconds
