JET2 transformation project with multiple transformations [message #4965] |
Sat, 17 March 2007 11:44  |
There is a problem defining additional transformations in JET
Transformation Project. For example, I create the JET2 Transformation
Project prj1. Now I can run JET transformation with id prj1. But if I
add one more transformation into project using org.eclipse.jet.transform
extension point then there is no way to run it using Run configuration.
Despite this, if my new transformation definition is first in list of
defined transformation then it is performed.
I tied to define different IDs for extension points and define different
template loaders but behavior stays the same.
Summary:
How to define several transformations in one transformation project with
ability to run them using launch configuration?
Vladimir
FUDForum. Page generated in 0.13610 seconds
