3.6 ecj and package-info.java [message #552597] |
Thu, 12 August 2010 18:16 |
Rob Hatcherson Messages: 33 Registered: July 2009 Location: Fort Worth, TX, USA |
Member |
I was attempting to build the open-source Janino project on Fedora 7 using the 3.6 ecj compiler. The author includes a package-info.java in one of his packages. When I attempt the buiId I get:
[javac] Compiling 97 source files to /usr/local/ZedaSoft/rhatcher/BuildOutput-main/ZedaSoft/Java/ ThirdParty/Janino/1.0/classes
[javac] ----------
[javac] 1. ERROR in /disk2/usr/local/ZedaSoft/rhatcher/prj-main/ZedaSoft/Java/Th irdParty/Janino/main/src/org/codehaus/commons/compiler/packa ge-info.java (at line 1)
[javac]
[javac] ^
[javac] The type package-info is already defined
[javac] ----------
[javac] 1 problem (1 error)
However, if I touch the package-info.java source file and re-run ant then it compiles the file ok. I thought this might be related to compiling multiple files at once, but after the build has failed the first time I can touch package-info.java plus any additional combination of files inside that package and it still builds ok.
If I ant clean, then ant again, the problem comes back as you might expect, but again only for the first build attempt.
javac doesn't have a problem with it.
Has anybody bumped into this?
FUDForum. Page generated in 0.03064 seconds
