Home » Eclipse Projects » Equinox » Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2?
Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #55593] Mon, 02 January 2006 10:28 Go to next message
Is the bundle manifest header Bundle-RequiredExecutionEnvironment
supported/respected in Eclipse 3.1 or, if not, will it be respected in 3.2?
I'm seeing the need to have the implementation of some of my stuff differ
depending on whether eclipse is running in a 1.4 or 1.5 VM.
Looking at the OSGI_R4.core spec it appears that one should be able to do
this:
Bundle-RequiredExecutionEnvironment:J2SE-1.4
or
Bundle-RequiredExecutionEnvironment:J2SE-1.5
comments?
Geoff
Re: Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #56650 is a reply to message #55593] Thu, 12 January 2006 15:12 Go to previous messageGo to next message
No comment?
Re: Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #57742 is a reply to message #55593] Mon, 23 January 2006 23:31 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Yup. This certainly works in 3.2. I don't remember if it works in 3.1.
Did you try it? Be sure to use 3.1.1 (upcoming 3.1.2). PDE is even tooling
this to ensure that bundles are being compiled against the correct JRE.
Jeff
"Geoff Longman" <glongman@gmail.com> wrote in message
news:335e4b22b81a98b36cf7b8e4e605af31$1@www.eclipse.org...
3.2?
> this:
> or
> comments?
> Geoff
Re: Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #58059 is a reply to message #57742] Wed, 25 January 2006 12:35 Go to previous messageGo to next message
Pefect. I'll give it a whirl.
Geoff
> Jeff
> 3.2?
>> this:
>> or
>> comments?
>> Geoff
Re: Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #58164 is a reply to message #58059] Thu, 26 January 2006 03:29 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
Please post back to let us know if it works and under which platforms
Stefan
> Cheers,
> Geoff
>> tooling
>> Jeff
>> 3.2?
>>> differ
>>> to do
>>> this:
>>> or
>>> comments?
>>> Geoff
Re: Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2? [message #58311 is a reply to message #58164] Thu, 26 January 2006 09:12 Go to previous message
Stefan, be more positive :-) It works. The only problem you might see is
if for some reason the System properties we use to detect the VM being run
differ wildly on some JRE. If that happens there are ways to tell the
framework what execution environment is being run and what other execution
environments it supports.
If you find any problems in this area, please let us know through bugzilla
Jeff
"Stefan Langer" <eclipse@bettsockentraeger.de> wrote in message
news:dra175$eqp$1@utils.eclipse.org...
> Regards
> Stefan
> > Cheers,
> > Geoff
3.1.
> >> tooling
> >> Jeff
> >> 3.2?
> >>> differ
> >>> to do
> >>> this:
> >>> or
> >>> comments?
> >>> Geoff
Previous Topic:Class Loading Architecture
Next Topic:Missing required bundle org.eclipse.ui.cheatsheets_0.0.0 Error
Current Time: Mon Jul 21 20:53:56 EDT 2025
Powered by FUDForum. Page generated in 0.04821 seconds
