Re: Improving xtext building [message #554459 is a reply to message #554450] |
Mon, 23 August 2010 09:07 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Alexandre,
do you mean the job is stuck and will never complete or does it just
take some time to finish the resource?
I'ld assume you are refering the the task "updating resource
description" during the build process? A long delay may be caused by
strong dependencies on many other resources which have to be loaded to
establish cross references for a certain resource. This may take some time.
If you feel that the build process is too slow or you have other
scalability issues, I'ld recommend to perform an in-depth analysis /
profiling for your particular language. Please don't hesitate to contact
us (see footer) if you need any project specific help that goes beyond
the support in this newsgroup.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 23.08.10 10:43, schrieb Alexandre Blanquart:
> I followed the blog entry but I am now encountering another problem
> reproductible on different platforms. Actually, the building project job
> blocks at resource 21, 25 or 1421 for 1466 resources.
> Do you have any idea about this problem?
> Alexandre
Re: Improving xtext building [message #555837 is a reply to message #552246] |
Sun, 29 August 2010 12:04 |
Johannes Stelzer Messages: 30 Registered: October 2009 |
Member |
I've encountered another problem:
I'm using the last nightly (since clustering is not in 1.0.1RC1).
I get this Message:
!MESSAGE Platform filter did not match: (& (osgi.os=linux) (osgi.arch=x86))
0 [main] ERROR org.eclipse.xtext.ui.shared.internal.Activator - org.eclipse.core.runtime.CoreException: Plug-in de.stelzer.sntsworkbench.ui was unable to load class org.eclipse.xtext.builder.clusterin.ClusteringModule.
I'm on Windows 7 x64 here...
[Updated on: Sun, 29 August 2010 12:06] Report message to a moderator
FUDForum. Page generated in 0.04891 seconds
