| Generic Web named expressions ({Id}.+?) - are these supported? [message #55555] |
Thu, 07 August 2008 14:05  |
Documentation for Generic Connector at
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Generic_W eb_Repository_Connector
indicates that I can define expressions like this:
Note: Query Pattern field should be a regexp with 1st matching group on
Issue ID and 2nd on Issue Description. Alternatively, you could use named
matching groups: ({Id}.+?), ({Description}.+?), ({Status}.+?), ({Owner}.+?)
and ({Type}.+?), then they can appear in query regexp in an arbitrary order.
The second option requires build 2.0.0v20070717 or later.
I tried to build pattern using the alternat form ... ({Id}.+?) ... but I get
expression errors.
I'm using Ganymede, and all mylyn related plugin jars have version numbers
of 3. something with build dates 2008...
The generic web plugin is
org.eclipse.mylyn.web.tasks_3.0.1.v20080721-2100-e3x.jar.
Question: Is this feature for naming the patterns supported, or possibly the
documentation is wrong?
Michael
| Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #55611 is a reply to message #55584] |
Thu, 07 August 2008 16:26   |
I have added a comment to the bug.
What I find is that {Id} causes the parsing error: null pointer. Any of the
other keywords cause a message that taskId and summary must be specified
(see bug for exact message).
Also, I believe that if using named matching groups that it is necessary for
all matching groups to be named. If this is a rule, the NOTE regarding the
alternate form using named matching groups should be updated.
Michael
"Steffen Pingel" <steffen.pingel@tasktop.com> wrote in message
news:g7fj4g$3r9$1@build.eclipse.org...
> The error you are seeing may be caused by a regression in Mylyn 3.0 that
> has
> been reported here:
> 243131: [web connector] named regex groups don't work with 3.4
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=243131
> Please comment on the bug report with the expression that is failing for
> you.
> Thanks.
> Steffen
>> ({Owner}.+?) and ({Type}.+?), then they can appear in query regexp in an
>> arbitrary order. The second option requires build 2.0.0v20070717 or
>> later.
>> get expression errors.
>> numbers
>> the documentation is wrong?
>> Michael
| Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #592295 is a reply to message #55555] |
Thu, 07 August 2008 15:41  |
The error you are seeing may be caused by a regression in Mylyn 3.0 that has
been reported here:
you.
Thanks.
Steffen
> arbitrary order. The second option requires build 2.0.0v20070717 or later.
> Michael
| Re: Generic Web named expressions ({Id}.+?) - are these supported? [message #592303 is a reply to message #55584] |
Michael
> has
> been reported here:
> you.
> Thanks.
> Steffen
>> later.
>> numbers
>> Michael
FUDForum. Page generated in 0.04043 seconds
