Home » Eclipse Projects » Eclipse Platform » CDT + JDT
CDT + JDT [message #55531] Fri, 30 May 2003 06:06 Go to next message
Hello all,
I have downloaded cdt-win32_1.1.0. When I plug it in Eclipse there is not
possibility to compile my Java projects because of my Java projects don't
know any JRE suddenly. In "Properties for Java_project"->Java Build Path is
message: "Build path entry is missing:
org.eclipse.jdt.launching.JRE_CONTAINER".
When I go to Window->Preferences->Java->Installed JREs there is nothing
spite I had set two JREs (1.3 and 1.4) and Add... button is disabled. Only
thing I can do is to press Search... button but when I locate the exact
directory with JRE installed Eclipse find nothing.
When I remove the CDT plug in everything works OK. It seems like a bug in
interaction between JDT and CDT, doesn't it?
Thank in advice,
Leo.
Re: CDT + JDT [message #55881 is a reply to message #55531] Fri, 30 May 2003 09:00 Go to previous message
Originally posted by: daniel.megert.gmx.net
Leo Papacek wrote:
>Hello all,
You can search bugzilla if a similar bug report exists and if not, add a
bug report. You might also want to check the archive of the
eclipse.tools.cdt newsgroup.
Dani
Previous Topic:[ANN] First Release of Input Simplifying Plug-In
Next Topic:Patching files (org.eclipse.compare.internal.patch)
Current Time: Tue Nov 18 11:01:01 EST 2025
Powered by FUDForum. Page generated in 0.04152 seconds
