Home » Archived » M2M (model-to-model transformation) » [ATL] Is ATL some oo-language?
[ATL] Is ATL some oo-language? [message #4941] Tue, 02 January 2007 13:51 Go to next message
Originally posted by: cb.infocity.de
for my thesis paper i need some answer to some simple question.:-)
For sure i should know the answer to this question, because i did my thesis
with ATL but i want to be sure i'm not writing
anything bad.;-)
OK so i want to write:
"Even if ATL is written in Java and the lastest ATL version (ATL 2006) can
deal with rule inheritance, ATL is not an object orientarted language.
It's an language which "works on" Models and Metamodels. ATL is "more"
highlevel compare to Java."
Can i write this?;-))
Well that's how i see this.;-)
Camil
Re: [ATL] Is ATL some oo-language? [message #5014 is a reply to message #4941] Wed, 03 January 2007 05:23 Go to previous messageGo to next message
Originally posted by: bezivin.univ-nantes.fr
Camil,
It is possible to write a non object-oriented language interpreter or IDE
with an OO language like Java, Eiffel, C# or Smalltalk.
(The reverse statement is also true)
For example you may write a functional or rule-based language in Java.
As a consequence your statement below
does not seem wrong to me. You make a difference between "rule inheritance"
and "class inheritance" which seems OK.
ATL is a modeling language, i.e. it is based on a given metamodel.
(ATL programs may be considered as models, conforming to the ATL metamodel)
All metamodels are not "object-oriented". UML class diagrams or Java
are exemples of OO metamodels. But we may think for example of a relational
metamodel which is not an OO metamodel. This makes MDE (Model Driven
Engineering)
a powerful multi-paradigm conceptual tool because it allows
to handle event-oriented, rule-oriented, and many others in the same
way as object-oriented systems.
Jean
"Camil Bartkowiak" <cb@infocity.de> a
Re: [ATL] Is ATL some oo-language? [message #5218 is a reply to message #5014] Thu, 04 January 2007 18:55 Go to previous message
Originally posted by: camil.cbartkowiak.de
Hello Jean,
thank you for your clearly answer. It helped me for my thesis paper.
Best regards
Camil
"Jean.Bezivin" <bezivin@univ-nantes.fr> schrieb im Newsbeitrag
news:eng06e$jt8$1@utils.eclipse.org...
> Camil,
> inheritance"
> metamodel)
> relational
> Engineering)
> Best regards,
> Jean
Previous Topic:[ATL] how to use entity reference in input model
Next Topic:Problems when copying properties from a class
Current Time: Sat Jul 12 06:13:00 EDT 2025
Powered by FUDForum. Page generated in 0.03528 seconds
