Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with Tomcat 6 & RAP 1.0
Problem with Tomcat 6 & RAP 1.0 [message #55462] Thu, 25 October 2007 13:43 Go to next message
Originally posted by: thomas.blattner.onlinehome.de
I have a problem when trying to deploy latest release of
org.eclipse.rap.demo.feature into tomcat 6.0.14
I follow the steps to create the war, without any problems or error
messages.
After deploying the war to tomcat, I only see in the log file of tomcat
somehting like "osgi>" and this a hundred thousand of times! After a while
I have to kill tomcat.
When I start the plugin inside Eclipse everything works just fine. I have
also tried to deploy the war which is shipped with the demo feature and
this just works fine!
Is there a problem with latest release plugins and tomcat 6.0.xx?
The framework looks very interesting, and as I have already done some RCP
applications, I'm very interested also in RAP, but not to be able to
deploy it is a showstopper.
Thank you.
Best regards
Thomas
Re: Problem with Tomcat 6 & RAP 1.0 [message #55515 is a reply to message #55462] Thu, 25 October 2007 16:44 Go to previous messageGo to next message
Originally posted by: b.muskalla.gmx.net
this sounds as you had the -console (OSGi console) in your
configuration. Be sure to remove it before deploying your application.
Greets
Benny
Thomas wrote:
> Hello,
> messages.
> while I have to kill tomcat.
> have also tried to deploy the war which is shipped with the demo feature
> and this just works fine!
> RCP applications, I'm very interested also in RAP, but not to be able to
> Thank you.
> Best regards
> Thomas
Re: Problem with Tomcat 6 & RAP 1.0 [message #55542 is a reply to message #55462] Thu, 25 October 2007 18:17 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Thomas,
over here the rapdemo works without any problems with tomcat 6.0.14
Here is the .war file that we are using:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/rap/rapdemo.war
The OSGi console is turned OFF in this war-archive. You can turn it on
for evaluation purposes, but it is recommended turning it off when
running in production environments.
Jochen
Thomas wrote:
> Hello,
> messages.
> Thank you.
> Best regards
> Thomas
Re: Problem with Tomcat 6 & RAP 1.0 [message #55927 is a reply to message #55542] Fri, 26 October 2007 13:32 Go to previous message
thanks a lot, this helped.
After commenting the commandline option in web.xml it works just fine.
Best regards
Thomas
Previous Topic:Architecture overview
Next Topic:Servlet delegate not registered
Current Time: Sun Jul 13 01:53:34 EDT 2025
Powered by FUDForum. Page generated in 0.03987 seconds
