Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Can I add my own class path entries to JETEmitter project
Can I add my own class path entries to JETEmitter project [message #55460] Sun, 01 October 2006 03:16 Go to next message
Hi All,
In my own plugin, I am calling generate method of
org.eclipse.emf.codegen.ecore.generator.Generator class (which is new in
codegen.ecore 2.2.1) to generate the code for my genModel. Earlier I used
to call generate method os the
org.eclipse.emf.codegen.ecore.genmodel.GenModel. However now its
depreciated.
Now the issue is since I am using customised jet templates to generate
codes I have to add a jar file available in my plugin to the jetEmitter
project's class path so that jetemitter project get comiled correctly.
Is it possible to add new classpath entries to jetemitter project with new
org.eclipse.emf.codegen.ecore.generator.Generator class ?
I tried creating the jetemitter project myself before calling the generate
method. However I found that my jetemitter project get overridden by the
jetemiiteer project created by calling generate method. In fact I found
that jet emitter project get created as follows in the execution path;
AbstractGeneratorAdapter=> getJETEmitter() => createJETEmitter()
genBaseGeneratorAdapter => addClasspathentries()
Is there a possibility to override the createJETEmitter() method of
AbstractGeneratorAdapter class? Or is there any other solution for this?
Can anyone help me resolve this issue?
Thanks in advance
Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55487 is a reply to message #55460] Sun, 01 October 2006 08:55 Go to previous messageGo to next message
--------------010703030409020103090507
Nalaka,
You can override createJETEMitter and you can also make your extension
use a different project by calling JETEmitter.setProjectName to
something other than .JETEmitters. The UML project overrides just the
addClasspathEntries method to add additional UML2-specific entries.
public class UML2GenBaseGeneratorAdapter
extends GenBaseGeneratorAdapter {
protected static void addUML2ClasspathEntries(JETEmitter jetEmitter)
throws JETException {
jetEmitter.addVariable("UML2_CODEGEN_ECORE", //$NON-NLS-1$
"org.eclipse.uml2.codegen.ecore"); //$NON-NLS-1$
public UML2GenBaseGeneratorAdapter(
GeneratorAdapterFactory generatorAdapterFactory) {
super(generatorAdapterFactory);
protected void *addClasspathEntries*(JETEmitter jetEmitter)
super.addClasspathEntries(jetEmitter);
addUML2ClasspathEntries(jetEmitter);
Nalaka Gamage wrote:
> Hi All,
> in codegen.ecore 2.2.1) to generate the code for my genModel. Earlier
> I used to call generate method os the
> depreciated.
> jetEmitter project's class path so that jetemitter project get comiled
> correctly. Is it possible to add new classpath entries to jetemitter
> project with new org.eclipse.emf.codegen.ecore.generator.Generator
> class ?
> generate method. However I found that my jetemitter project get
> overridden by the jetemiiteer project created by calling generate
> method. In fact I found that jet emitter project get created as
> follows in the execution path; AbstractGeneratorAdapter=>
> getJETEmitter() => createJETEmitter() genBaseGeneratorAdapter =>
> Thanks in advance
> Nalaka
<html>
<head>
http-equiv="Content-Type">
</head>
Nalaka,<br>
<br>
Re: Can I add my own class path entries to JETEmitter project [message #55514 is a reply to message #55487] Mon, 02 October 2006 03:30 Go to previous messageGo to next message
Hi Merks,
Thanks for the reply which is very useful information.
I went through the source code of org.eclipse.uml2.codegen.ecore_1.2.1
plugin to get better understanding of your solution. Its clear creating a
new class extending GenBaseGeneratorAdapter and overiding the
addClasspathEntries should do the trick.
However I am bit stuck to identify how we are going to make sure that our
extended class is used instead of GenBaseGeneratorAdapter class. Do we
have to create a new adapter factory class as well? It will be great if
you can explain how we are going to integrate our extended class.
I can see that in uml2.codgen.ecore plugin, they have created their own
GenClassGeneratorAdapter class that extends
org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGen eratorAdapter
and in this class they have override addClasspathEntries as follows;
protected void addClasspathEntries(JETEmitter jetEmitter)
*UML2GenBaseGeneratorAdapter.addUML2ClasspathEntries(jetEmit ter);*
Is this the trick you are doing or this is related to some other
requirement? If so still how are we making sure that our version of
GenClassGeneratorAdapter class is used?
My requirement is simply to add new class path entry to the JETEmitter
project.
I highly appreciate your response.
Nalaka
Ed Merks wrote:
> Nalaka,
>> Hi All,
>> depreciated.
>> class ?
>> Thanks in advance
>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55540 is a reply to message #55514] Mon, 02 October 2006 07:38 Go to previous messageGo to next message
Hi Merks and All,
I further researched into org.eclipse.uml2.codegen.ecore_1.2.1 code base
and found that in the plugin.xml,following extension point entries
available;
<extension point="org.eclipse.emf.codegen.ecore.generatorAdapters">
<adapterFactory
modelPackage = "http://www.eclipse.org/uml2/1.1.0/GenModel"
class=" org.eclipse.uml2.codegen.ecore.genmodel.generator.GenModelGe neratorAdapterFactory "/>
<adapterFactory
class=" org.eclipse.uml2.codegen.ecore.genmodel.generator.UML2GenMod elGeneratorAdapterFactory "/>
</extension>
In my case, I am also calling generete method from within my own plugin. I
feel I may follow same approach (correct me If I am wrong). Still I am not
exactly sure which factory to be extended
Should I use the exact same extension aproach as above or should there be
a simpler extension approach.
May I add the extension points in *my own plugin*, in that case do I have
to overide the org.eclipse.emf.codegen.ecore.generator.Generator class as
well?
Unfortunately there is no direct factory class for GenBaseGeneratorAdapter
(which I am now extending). Therefore, In my case also do I have to go
through the GenModelGeneratorAdapterFactory class extension as
uml2.codegen.ecore_1.2.1 does?
Do you feel this extension approach is feasible?
Please correct me if I am in a wrong path?
Thanks in advance,
Nalaka
> Hi Merks,
> project.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>>> Hi All,
>>> depreciated.
>>> class ?
>>> Thanks in advance
>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55567 is a reply to message #55514] Mon, 02 October 2006 08:01 Go to previous messageGo to next message
Nalaka,
I imagine you'll need to create a specialized factory that creates your
specialized adapters for each of the adapters the factory currently
creates. How were you previously solving this problem before we
provided the adapters?
> Hi Merks,
> Thanks for the reply which is very useful information. I went through
> the source code of org.eclipse.uml2.codegen.ecore_1.2.1 plugin to get
> better understanding of your solution. Its clear creating a new class
> addClasspathEntries should do the trick. However I am bit stuck to
> identify how we are going to make sure that our extended class is used
> instead of GenBaseGeneratorAdapter class. Do we have to create a new
> adapter factory class as well? It will be great if you can explain how
> own GenClassGeneratorAdapter class that extends
> project.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>> extension use a different project by calling
>> JETEmitter.setProjectName to something other than .JETEmitters. The
>> UML project overrides just the addClasspathEntries method to add
>> jetEmitter)
>>> Hi All,
>>> new in codegen.ecore 2.2.1) to generate the code for my genModel.
>>> Earlier I used to call generate method os the
>>> depreciated.
>>> generate codes I have to add a jar file available in my plugin to
>>> the jetEmitter project's class path so that jetemitter project get
>>> comiled correctly. Is it possible to add new classpath entries to
>>> this?
>>> Thanks in advance
>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55595 is a reply to message #55540] Mon, 02 October 2006 08:15 Go to previous messageGo to next message
Nalaka,
Probably you'll want to create a Generator with an empty registry (new
Generator(new DelegateRegistry()) and populate that registry with your
specialized GenModelGeneratorAdapterFactory.
> Hi Merks and All,
> base and found that in the plugin.xml,following extension point
> entries available;
> <adapterFactory
> modelPackage =
> <adapterFactory
> modelPackage =
> </extension>
> plugin. I feel I may follow same approach (correct me If I am wrong).
> Still I am not exactly sure which factory to be extended
> be a simpler extension approach.
> have to overide the org.eclipse.emf.codegen.ecore.generator.Generator
> class as well?
> GenBaseGeneratorAdapter (which I am now extending). Therefore, In my
> case also do I have to go through the GenModelGeneratorAdapterFactory
> class extension as uml2.codegen.ecore_1.2.1 does?
> Thanks in advance,
> Nalaka
>> Hi Merks,
>> used instead of GenBaseGeneratorAdapter class. Do we have to create a
>> new adapter factory class as well? It will be great if you can
>> JETEmitter project.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>> jetEmitter)
>>>> Hi All,
>>>> depreciated.
>>>> this?
>>>> Thanks in advance
>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55649 is a reply to message #55567] Mon, 02 October 2006 09:11 Go to previous messageGo to next message
Hi Merks,
Thanks for the reply.
Earlier we were creating JETEmittersProject by calling our own method
createJETEmittersProject oursrselves before calling the generate method of
org.eclipse.emf.codegen.ecore.genmodel class.
public static void createJETEmittersProject(IProgressMonitor
progressMonitor ) throws Exception {
List classpathEntries = new ArrayList();
addVariable("EMF_CODEGEN", "org.eclipse.emf.codegen", classpathEntries);
addVariable("EMF_CODEGEN_ECORE", "org.eclipse.emf.codegen.ecore",
classpathEntries);
addVariable("EMF_COMMON", "org.eclipse.emf.common", classpathEntries);
addVariable("EMF_ECORE", "org.eclipse.emf.ecore", classpathEntries);
createProject(progressMonitor, ".JETEmitters", classpathEntries);
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IProject project = workspace.getRoot().getProject(".JETEmitters");
XXXXUtil.addClasspathEntry(project, "XXXX_VARIABLE_NAME", "xxxxx.jar",
"com....pluginid.xxxx", progressMonitor); // This is our internal method
to add the additional class path entry
Then also we had subclass GenModelImpl class and override the
createJETEmitter method as follows;
public class XXXXGenModelImpl extends GenModelImpl {
* Overrided parant class method
protected JETEmitter createJETEmitter(String relativeTemplateURI)
ClassLoader classLoader =
XXXXOUrPlugin.getDefault().getClass().getClassLoader();
JETEmitter jetEmitter =
new JETEmitter(getTemplatePath(), relativeTemplateURI, classLoader)
public void initialize(IProgressMonitor progressMonitor) throws
JETException
addVariable("EMF_CODEGENYYYY", "org.eclipse.emf.codegen");
addVariable("EMF_CODEGEN_ECORE", "org.eclipse.emf.codegen.ecore");
addVariable("EMF_COMMON", "org.eclipse.emf.common");
addVariable("EMF_ECORE", "org.eclipse.emf.ecore");
super.initialize(progressMonitor);
return jetEmitter;
Note that here we are using the class loader obtained through our plugin
as well.
Then we had instantiated our extended gen model as follows;
GenModel genModel = new
XXXXGenModelImpl((GenModel)genModelResource.getContents().ge t(0),(ResourceImpl)genModelResource
genModel.generate(new SubProgressMonitor(progressMonitor, 1));
In this way the jetemitter project we had created by ourselves never got
overidden, but when we are calling generete method in newly intrdused
org.eclipse.emf.codegen.ecore.generator.Generator class our GETEmitter
project that have additional class path entries get override.
This is our original issue that we are looking for a new fix.
Nalaka
Ed Merks wrote:
> Nalaka,
>> Hi Merks,
>> project.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>> jetEmitter)
>>>> Hi All,
>>>> depreciated.
>>>> this?
>>>> Thanks in advance
>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #55676 is a reply to message #55649] Mon, 02 October 2006 09:46 Go to previous messageGo to next message
Nalaka,
I see. So our changes haven't made life simpler for you. :-( We could
probably make life a lot simpler if we added a feature similar to "Model
Plug-in Variables" (which specifies additional plugin dependencies for
the generated model project) but for specifying additional plugins to be
added to the project for compiling the dynamic templates, e.g.,
MY_UTILITIES=org.example.my.utilities would specify the variable name
and the plugin ID. If that seems useful, please open a feature request
for it. This is somewhat related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=147318 where the desire is
to be able to point to a project where the templates have already been
compiled by virtue of that project having a JET Nature.
> Hi Merks,
> method of org.eclipse.emf.codegen.ecore.genmodel class.
> classpathEntries);
> classpathEntries);
> method to add the additional class path entry
> JETEmitter jetEmitter = new JETEmitter(getTemplatePath(),
> JETException
> return jetEmitter;
> plugin as well.
> got overidden, but when we are calling generete method in newly
> intrdused org.eclipse.emf.codegen.ecore.generator.Generator class our
> GETEmitter project that have additional class path entries get override.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>> your specialized adapters for each of the adapters the factory
>> currently creates. How were you previously solving this problem
>> before we provided the adapters?
>>> Hi Merks,
>>> creating a new class extending GenBaseGeneratorAdapter and overiding
>>> the addClasspathEntries should do the trick. However I am bit stuck
>>> to identify how we are going to make sure that our extended class is
>>> a new adapter factory class as well? It will be great if you can
>>> JETEmitter project.
>>> Thanks
>>> Nalaka
>>> Ed Merks wrote:
>>>> Nalaka,
>>>> The UML project overrides just the addClasspathEntries method to
>>>> jetEmitter)
>>>>> Hi All,
>>>>> depreciated.
>>>>> of AbstractGeneratorAdapter class? Or is there any other solution
>>>>> for this?
>>>>> Thanks in advance
>>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #56131 is a reply to message #55676] Tue, 03 October 2006 10:24 Go to previous messageGo to next message
Originally posted by: giacomin.vettatech.com
Nalaka,
Please let me know when you create the feature request because I'm also
interested in.
Ricardo Giacomin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:efr57l$c17$1@utils.eclipse.org...
> Nalaka,
> Plug-in Variables" (which specifies additional plugin dependencies for the
> generated model project) but for specifying additional plugins to be added
> MY_UTILITIES=org.example.my.utilities would specify the variable name and
> the plugin ID. If that seems useful, please open a feature request for
>> Hi Merks,
>> classpathEntries);
>> classpathEntries);
>> JETException
>> return jetEmitter;
>> as well.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>>> Hi Merks,
>>>> extending GenBaseGeneratorAdapter and overiding the addClasspathEntries
>>>> should do the trick. However I am bit stuck to identify how we are
>>>> going to make sure that our extended class is used instead of
>>>> GenBaseGeneratorAdapter class. Do we have to create a new adapter
>>>> factory class as well? It will be great if you can explain how we are
>>>> project.
>>>> Thanks
>>>> Nalaka
>>>> Ed Merks wrote:
>>>>> Nalaka,
>>>>> jetEmitter)
>>>>>> Hi All,
>>>>>> depreciated.
>>>>>> generate codes I have to add a jar file available in my plugin to the
>>>>>> this?
>>>>>> Thanks in advance
>>>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #56179 is a reply to message #56131] Tue, 03 October 2006 11:24 Go to previous messageGo to next message
Ricardo,
You're more than welcome to open it yourself. I think it would be very
useful, but if the community doesn't open a feature request, then that
tells me it's not very important...
Ricardo Giacomin wrote:
> Nalaka,
> interested in.
Re: Can I add my own class path entries to JETEmitter project [message #56263 is a reply to message #56179] Wed, 04 October 2006 00:20 Go to previous message
Hi All,
I have added a feature request for this.
Bug 159691
https://bugs.eclipse.org/bugs/show_bug.cgi?id=159691
Nalaka
Ed Merks wrote:
> Ricardo,
>> Nalaka,
>> interested in.
>> Thanks,
Re: Can I add my own class path entries to JETEmitter project [message #593143 is a reply to message #55460] Sun, 01 October 2006 08:55 Go to previous message
Nalaka,
> Hi All,
> depreciated.
> class ?
> Thanks in advance
> Nalaka
<html>
<head>
</head>
Nalaka,<br>
<br>
Re: Can I add my own class path entries to JETEmitter project [message #593153 is a reply to message #55487] Mon, 02 October 2006 03:30 Go to previous message
Hi Merks,
project.
Nalaka
Ed Merks wrote:
> Nalaka,
>> Hi All,
>> depreciated.
>> class ?
>> Thanks in advance
>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593164 is a reply to message #55514] Mon, 02 October 2006 07:38 Go to previous message
Hi Merks and All,
available;
<adapterFactory
<adapterFactory
</extension>
well?
Thanks in advance,
Nalaka
> Hi Merks,
> project.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>>> Hi All,
>>> depreciated.
>>> class ?
>>> Thanks in advance
>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593170 is a reply to message #55514] Mon, 02 October 2006 08:01 Go to previous message
Nalaka,
> Hi Merks,
> project.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>> jetEmitter)
>>> Hi All,
>>> depreciated.
>>> this?
>>> Thanks in advance
>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593185 is a reply to message #55540] Mon, 02 October 2006 08:15 Go to previous message
Nalaka,
> Hi Merks and All,
> entries available;
> <adapterFactory
> modelPackage =
> <adapterFactory
> modelPackage =
> </extension>
> class as well?
> Thanks in advance,
> Nalaka
>> Hi Merks,
>> JETEmitter project.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>> jetEmitter)
>>>> Hi All,
>>>> depreciated.
>>>> this?
>>>> Thanks in advance
>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593203 is a reply to message #55567] Mon, 02 October 2006 09:11 Go to previous message
Hi Merks,
classpathEntries);
JETException
return jetEmitter;
as well.
Nalaka
Ed Merks wrote:
> Nalaka,
>> Hi Merks,
>> project.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>> jetEmitter)
>>>> Hi All,
>>>> depreciated.
>>>> this?
>>>> Thanks in advance
>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593213 is a reply to message #55649] Mon, 02 October 2006 09:46 Go to previous message
Nalaka,
> Hi Merks,
> classpathEntries);
> classpathEntries);
> JETException
> return jetEmitter;
> plugin as well.
> Thanks
> Nalaka
> Ed Merks wrote:
>> Nalaka,
>>> Hi Merks,
>>> JETEmitter project.
>>> Thanks
>>> Nalaka
>>> Ed Merks wrote:
>>>> Nalaka,
>>>> jetEmitter)
>>>>> Hi All,
>>>>> depreciated.
>>>>> for this?
>>>>> Thanks in advance
>>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593440 is a reply to message #55676] Tue, 03 October 2006 10:24 Go to previous message
Nalaka,
interested in.
Ricardo Giacomin
> Nalaka,
>> Hi Merks,
>> classpathEntries);
>> classpathEntries);
>> JETException
>> return jetEmitter;
>> as well.
>> Thanks
>> Nalaka
>> Ed Merks wrote:
>>> Nalaka,
>>>> Hi Merks,
>>>> project.
>>>> Thanks
>>>> Nalaka
>>>> Ed Merks wrote:
>>>>> Nalaka,
>>>>> jetEmitter)
>>>>>> Hi All,
>>>>>> depreciated.
>>>>>> this?
>>>>>> Thanks in advance
>>>>>> Nalaka
Re: Can I add my own class path entries to JETEmitter project [message #593469 is a reply to message #56131] Tue, 03 October 2006 11:24 Go to previous message
Ricardo,
> Nalaka,
> interested in.
Re: Can I add my own class path entries to JETEmitter project [message #593525 is a reply to message #56179] Wed, 04 October 2006 00:20 Go to previous message
Hi All,
Bug 159691
Nalaka
Ed Merks wrote:
> Ricardo,
>> Nalaka,
>> interested in.
>> Thanks,
Previous Topic:Unittests for java batch constraints
Next Topic:Running EMFT Transaction Standalone
Current Time: Sun Jul 27 06:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.08570 seconds
