Home » Eclipse Projects » DTP » Datatools Install/Uninstall Problems
Datatools Install/Uninstall Problems [message #55449] Wed, 15 April 2009 13:12 Go to next message
All,
There have been a few similar posts recently that seem to center on the
topic of install/uninstall problems wrt the set of datatools so I thought
I'd weigh in as well. I too am having problems.
Here's my question:
If I go in and delete the dtp related features and plug ins manually, will
I break anything else?
I tried to install the plugin for Google Web Toolkit 1.6 using their
update site and got the following error:
An error occurred while collecting items to be installed
Error closing the output stream for
org.eclipse.datatools.sqldevtools.data.feature/
org.eclipse.update.feature/1.6.2 ... The error message it goes on, full
text of the output is below.
I tried to uninstall dtp and got similar errors. So, I can't even get rid
of dtp.
FULL TEXT:
org.eclipse.update.feature/1.6.2.v200810071455-3109oA55V589K 5QA5 on
repository file:/C:/Program Files/eclipse-ganymede/.
Error unzipping C:\DOCUME~1\groberts\LOCALS~1\Temp
\org.eclipse.datatools.sqldevtools.data.feature_1.6.2.v20081 0071455-3109oA55V589K5QA54838407210649109424.jar:
Invalid zip file format
Problems downloading artifact:
osgi.bundle,org.eclipse.datatools.sqltools.data.core,
1.1.0.v200901140930.
Exception connecting to
http://download.eclipse.org/datatools/downloads/drops/N_upda tes/plugins/org.eclipse.datatools.sqltools.data.core_1.1.0.v 200901140930.jar.
Re: Datatools Install/Uninstall Problems [message #55556 is a reply to message #55449] Wed, 15 April 2009 19:10 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hey Geoffry...
Yeah... I know there are a ton of weird issues going on.
Couple of questions... 1) What version of Eclipse did you have prior to
using the Update Manager? 2) What version of DTP were you installing? 1.6.2?
As for dependencies.. WTP depends on DTP in some places. BIRT does too. I'm
not sure what the Google Web Toolkit uses.
--Fitz
"Geoffry Roberts" <geoff.roberts@qinetiq-na.com> wrote in message
news:1f6e6599405be037e4a92c22b798493a$1@www.eclipse.org...
> All,
> Here's my question:
> of dtp.
> FULL TEXT:
Re: Datatools Install/Uninstall Problems [message #55662 is a reply to message #55556] Thu, 16 April 2009 12:35 Go to previous messageGo to next message
On my problem machine, I'm running eclipse 3.4.2 and dtp 1.6.2.
On two other machines, its eclipse 3.4.0 and dtp 1.6.0; and GWT 1.6
installed with no problem.
Sounds like I need to roll back a version or two.
Brian Fitzpatrick wrote:
> Hey Geoffry...
> --Fitz
>> All,
>> Here's my question:
>> of dtp.
>> FULL TEXT:
>> Error unzipping C:DOCUME~1grobertsLOCALS~1Temp
org.eclipse.datatools.sqldevtools.data.feature_1.6.2.v200810 071455-3109oA55V589K5QA54838407210649109424.jar:
Re: Datatools Install/Uninstall Problems [message #56128 is a reply to message #55662] Fri, 01 May 2009 17:26 Go to previous messageGo to next message
Hi again...
We're trying to narrow down a reproducible scenario to try and figure out
what's going on. We've started to collect details here:
http://wiki.eclipse.org/DTP_1.6.2_Update_Manager_Issues
Please let us know if you find out anything else and we'll continue to bang
on this.
Thanks.
--Fitz
news:c38c905eb20a2fea56989d2354862ead$1@www.eclipse.org...
>> Hey Geoffry...
>> 1.6.2?
>> I'm not sure what the Google Web Toolkit uses.
>> --Fitz
>>> All,
>>> thought I'd weigh in as well. I too am having problems.
>>> Here's my question:
>>> will I break anything else?
>>> rid of dtp.
>>> FULL TEXT:
Re: Datatools Install/Uninstall Problems [message #511689 is a reply to message #55449] Tue, 02 February 2010 09:40 Go to previous message
I am having a problem getting 1.7.1 to work properly.
If I install in a Galileo classic and open the datatools perspective directly after I do the install and restart, it seems to work.
If I do the same, and I do not open the datatools perspective immediately, and install more plugins, then it doesn't work. What I see instead is that the ODA data sources only has the "Flat File Data Source" and that there are no database drivers.
Nathan
Re: Datatools Install/Uninstall Problems [message #595499 is a reply to message #55449] Wed, 15 April 2009 19:10 Go to previous message
Hey Geoffry...
--Fitz
> All,
> Here's my question:
> of dtp.
> FULL TEXT:
Re: Datatools Install/Uninstall Problems [message #595537 is a reply to message #55556] Thu, 16 April 2009 12:35 Go to previous message
> Hey Geoffry...
> --Fitz
>> All,
>> Here's my question:
>> of dtp.
>> FULL TEXT:
Re: Datatools Install/Uninstall Problems [message #595677 is a reply to message #55662] Fri, 01 May 2009 17:26 Go to previous message
Hi again...
on this.
Thanks.
--Fitz
>> Hey Geoffry...
>> 1.6.2?
>> --Fitz
>>> All,
>>> Here's my question:
>>> rid of dtp.
>>> FULL TEXT:
Re: Datatools Install/Uninstall Problems [message #597162 is a reply to message #55449] Tue, 02 February 2010 09:40 Go to previous message
Nathan
Previous Topic:SQLModel doesn't use containment references ?
Next Topic:Can't get JDBC connection to DB2
Current Time: Wed Jul 30 15:56:38 EDT 2025
Powered by FUDForum. Page generated in 1.06890 seconds
