Home » Eclipse Projects » DTP » Datatools Install/Uninstall Problems
| Re: Datatools Install/Uninstall Problems [message #511689 is a reply to message #55449] |
Tue, 02 February 2010 09:40  |
I am having a problem getting 1.7.1 to work properly.
If I install in a Galileo classic and open the datatools perspective directly after I do the install and restart, it seems to work.
If I do the same, and I do not open the datatools perspective immediately, and install more plugins, then it doesn't work. What I see instead is that the ODA data sources only has the "Flat File Data Source" and that there are no database drivers.
Nathan
| Re: Datatools Install/Uninstall Problems [message #597162 is a reply to message #55449] |
Nathan
Current Time: Mon Oct 27 23:00:39 EDT 2025
Powered by FUDForum. Page generated in 0.24539 seconds
