Can't layout polygons [message #550758] |
Wed, 04 August 2010 09:28 |
Arto Jarvinen Messages: 32 Registered: May 2010 Location: Sweden |
Member |
I'm experimenting with my first GMF project and trying to create an figure that has the same layout as the "actor" figure in the GMF tutorial part 3 but with a centered label at the bottom. This has proven very hard. Using the grid layout I can use (at least) ellipses and rectangles and a label and get my desired layout. But when I throw in a polygon, I get a totally different behavior. There are more details on my blog (see signature) but essentially my question is: are polygons supposed to be treated differently from other more basic geometric shapes when it comes to layout (and why in that case) or is this a bug that may be fixed in the future? Any work-around hints would also be welcome. Thanks! -A
Edit: I'm using the DSL Toolkit "distribution" of Eclipse (Version: 1.0.0, Build id: 20090703-0844)
Blog: http://www.ostrogothia.com/process/
[Updated on: Thu, 05 August 2010 11:25] Report message to a moderator
FUDForum. Page generated in 0.03121 seconds
