FTP next and finish button disabled [message #55434] |
Sun, 05 December 2004 17:01  |
Originally posted by: stefano.bizzi.bluepinetech.com
Hello all,
Probably I am just missing something obvious. I tested the ftp import
locally and everything worked smoothly, so I tried to use it on a remote
server I have. After it connects to the remote server it correctly
retrieves the directory list but right after that I get the "select the
remote folder" dialog and, even if I select something, the next and
finish button stay disabled.
As I said with my local ftp server it worked great and I was able to do
everything I needed. I checked the remote server with the shell ftp
command and it worked perfectly. My firewall is disabled but I am using
a router.
What am I doing wrong?
Thank you all in advance
Stefano
Re: FTP next and finish button disabled [message #57115 is a reply to message #55434] |
Tue, 21 December 2004 12:08  |
Stefano wrote:
> Hello all,
> a router.
> Stefano
Issue resolved... apparently it was the Eclipse version I was using
(3.1). I installed 3.0RC3 that is more compatible with MyEclipse and
everything is working now.
Stefano
FUDForum. Page generated in 0.03028 seconds
