Home » Archived » BIRT » Week Interval - Bug or Feature?
Week Interval - Bug or Feature? [message #55343] Fri, 08 July 2005 14:28 Go to next message
Originally posted by: none.none.none
Creating a group with a 1 week interval, I expected it to be based on 'true'
weeks rather based on arbitrary start points.
For example, the user inputs a start date and an end date for the report...
--If the user puts in 6/10/05-7/10/05, then BIRT will group weeks as
6/10/05,6/17/05,6/24/05
I'm using 1.01 M1
Re: Week Interval - Bug or Feature? [message #55371 is a reply to message #55343] Fri, 08 July 2005 14:37 Go to previous messageGo to next message
Oops... accidentally sent that before it was done. So here it is again...
weeks rather than arbitrary start points.
--If the user puts in 6/10/05-7/1/05, then BIRT will group weeks as
6/10/05,6/17/05,6/24/05...
--If the user puts in 6/11/05-7/1/05, then BIRT will group weeks as
6/11/05,6/18/05,6/25/05...
So in other words, BIRT seems to simply take the start date and increment it
by 7 days... regardless what day of the week they fall on.
However, it does seem to work as I would expect for the month interval.
It'll group on month beginnings where it can.
I'm using 1.01 M1
So is this a bug, or is it intentional?
"chris" <none@none.none> wrote in message
news:damgjt$bug$1@news.eclipse.org...
> 'true' weeks rather based on arbitrary start points.
> report...
> I'm using 1.01 M1
Re: Week Interval - Bug or Feature? [message #55693 is a reply to message #55371] Sun, 10 July 2005 03:35 Go to previous message
Chris
Could you log a bugzilla entry on the behavior you expect? Group by
"week" and group by 7days on a date fields should be handled differently, I
think what you see is a bug for grouping by "week".
Wenfeng
news:damh59$cjf$1@news.eclipse.org...
> 'true' weeks rather than arbitrary start points.
> report...
> it by 7 days... regardless what day of the week they fall on.
> I'm using 1.01 M1
>> report...
>> I'm using 1.01 M1
Previous Topic:print the report
Next Topic:problems creating a bar chart
Current Time: Sat Jul 26 23:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.55801 seconds
