Home » Eclipse Projects » Remote Application Platform (RAP) » Exception when shutting down Equinox service
Exception when shutting down Equinox service [message #55326] Thu, 25 October 2007 01:19 Go to next message
I used 'close' command to shutdown & exit Equinox service, but it threw
the following exception:
WARNING: EXCEPTION
org.eclipse.ui.internal.services.RegistryPersistence$4.befor eDestroy(RegistryPersistence.java:593)
org.eclipse.rwt.internal.service.SessionStoreImpl.valueUnbou nd(SessionStoreImpl.java:130)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.unb indValue(AbstractSessionManager.java:923)
org.mortbay.jetty.servlet.AbstractSessionManager$Session.inv alidate(AbstractSessionManager.java:731)
org.mortbay.jetty.servlet.AbstractSessionManager.stop(Abstra ctSessionManager.java:498)
org.mortbay.jetty.servlet.ServletHandler.doStop(ServletHandl er.java:475)
at org.mortbay.util.Container.stop(Container.java:154)
at org.mortbay.http.HttpContext.doStop(HttpContext.java:1760)
at org.mortbay.http.HttpContext.stop(HttpContext.java:1728)
at org.mortbay.http.HttpServer.doStop(HttpServer.java:751)
org.eclipse.equinox.http.jetty.internal.HttpServerManager.sh utdown(HttpServerManager.java:122)
org.eclipse.equinox.http.jetty.internal.Activator.stop(Activ ator.java:86)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1032)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1028)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:396)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.java:400)
org.eclipse.core.runtime.internal.adaptor.BundleStopper.basi cStopBundles(BundleStopper.java:86)
org.eclipse.core.runtime.internal.adaptor.BundleStopper.stop Bundles(BundleStopper.java:73)
org.eclipse.core.runtime.internal.adaptor.EclipseAdaptorHook .frameworkStopping(EclipseAdaptorHook.java:156)
org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStopping(B aseAdaptor.java:288)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:538)
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:449)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._close(FrameworkCommandProvider.java:1098)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Thread.java:534)
The exception wasn't thrown if I didn't invoke my application before
shutting down Equinox.
Any ideas ?
Best Regards,
Setya
Re: Exception when shutting down Equinox service [message #55629 is a reply to message #55326] Fri, 26 October 2007 01:52 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
see news:ffrurh$k0a$1@build.eclipse.org.
Ciao
Frank
"Setya" <jsetya@gmail.com> schrieb im Newsbeitrag
news:5963efe105eca84036cd5449095ebdc0$1@www.eclipse.org...
> WARNING: EXCEPTION java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas ?
> Best Regards,
> Setya
Re: Exception when shutting down Equinox service [message #73524 is a reply to message #55629] Mon, 11 February 2008 16:43 Go to previous messageGo to next message
We have a similar problem on Tomcat.
We deploy our war, the rap application works.
We shutdown tomcat, and get a stack trace similar to the following.
Then, our application won't restart (upon tomcat restart), unless we
remove the files under catalina.home/work/
Any idea on how to fix this?
Patrick
Frank Appel wrote:
> Ciao
> Frank
>> at
>> at
>> at
[snip...]
Re: Exception when shutting down Equinox service [message #73614 is a reply to message #73524] Tue, 12 February 2008 10:52 Go to previous messageGo to next message
I am seeing the same problem when restarting Tomcat
(news://news.eclipse.org:119/foqjbh$bd6$1@build.eclipse.org)
but do not see the stack trace you do when I shut down. I restart using
the Tomcat Configuration manager, stop service and start service
commands (in Windows, context menu commands on the notification area
icon for Tomcat).
Where do you see this stack trace?
Ryan
Patrick Turcotte wrote:
> Patrick
> Frank Appel wrote:
>> Ciao
>> Frank
>>> Hi,
>>> threw the following exception:
>>> at
>>> at
>>> at
> [snip...]
Re: Exception when shutting down Equinox service [message #73632 is a reply to message #73614] Tue, 12 February 2008 11:14 Go to previous messageGo to next message
I see it in $CATALINA_HOME/logs/catalina.out
(Seems I forgot to mention we are using Tomcat 5.5, Java 6 on Ubuntu)
Patrick
Here is the complete stack
Feb 12, 2008 11:11:13 AM org.apache.catalina.session.StandardManager stop
SEVERE: Exception unloading sessions to persistent storage
org.eclipse.ui.internal.services.RegistryPersistence.dispose (Unknown Source)
org.eclipse.ui.internal.menus.MenuPersistence.dispose(Unknow n Source)
org.eclipse.ui.internal.menus.WorkbenchMenuService.dispose(U nknown Source)
org.eclipse.ui.internal.services.ServiceLocator.dispose(Unkn own Source)
at org.eclipse.ui.internal.Workbench.shutdown(Unknown Source)
at org.eclipse.ui.internal.Workbench.busyClose(Unknown Source)
at org.eclipse.ui.internal.Workbench.access$6(Unknown Source)
at org.eclipse.ui.internal.Workbench$14.run(Unknown Source)
at org.eclipse.swt.custom.BusyIndicator.showWhile(Unknown Source)
at org.eclipse.ui.internal.Workbench.close(Unknown Source)
at org.eclipse.ui.internal.Workbench$2.run(Unknown Source)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(Unknown
Source)
org.eclipse.ui.internal.Workbench$ShutdownHandler.beforeDest roy(Unknown
Source)
org.eclipse.rwt.internal.service.SessionStoreImpl.valueUnbou nd(Unknown
Source)
org.apache.catalina.session.StandardSession.removeAttributeI nternal(StandardSession.java:1615)
org.apache.catalina.session.StandardSession.writeObject(Stan dardSession.java:1458)
org.apache.catalina.session.StandardSession.writeObjectData( StandardSession.java:938)
org.apache.catalina.session.StandardManager.doUnload(Standar dManager.java:516)
org.apache.catalina.session.StandardManager.unload(StandardM anager.java:462)
org.apache.catalina.session.StandardManager.stop(StandardMan ager.java:666)
org.apache.catalina.core.StandardContext.stop(StandardContex t.java:4358)
org.apache.catalina.core.ContainerBase.removeChild(Container Base.java:892)
org.apache.catalina.startup.HostConfig.undeployApps(HostConf ig.java:1164)
org.apache.catalina.startup.HostConfig.stop(HostConfig.java: 1135)
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostCo nfig.java:312)
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent (LifecycleSupport.java:119)
org.apache.catalina.core.ContainerBase.stop(ContainerBase.ja va:1054)
org.apache.catalina.core.ContainerBase.stop(ContainerBase.ja va:1066)
org.apache.catalina.core.StandardEngine.stop(StandardEngine. java:447)
org.apache.catalina.core.StandardService.stop(StandardServic e.java:512)
org.apache.catalina.core.StandardServer.stop(StandardServer. java:743)
at org.apache.catalina.startup.Catalina.stop(Catalina.java:601)
at org.apache.catalina.startup.Bootstrap.stop(Bootstrap.java:30 6)
org.apache.commons.daemon.support.DaemonLoader.stop(DaemonLo ader.java:200)
Ryan Donnelly wrote:
> icon for Tomcat).
> Ryan
Re: Exception when shutting down Equinox service [message #73864 is a reply to message #73632] Thu, 14 February 2008 03:15 Go to previous messageGo to next message
which version of RAP do you use? We did some bugfixes around this stuff
which are available in CVS since the beginning of last week.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Patrick Turcotte [mailto:patrek@gmail.com]
Bereitgestellt: Dienstag, 12. Februar 2008 17:14
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Exception when shutting down Equinox service
Betreff: Re: Exception when shutting down Equinox service
Patrick
stop
Source)
Source)
Source)
Source)
Source)
Source)
java:1458)
ion.java:938)
a:516)
462)
6)
2)
2)
pport.java:119)
a:39)
Impl.java:25)
a:39)
Impl.java:25)
0)
> using the Tomcat Configuration manager, stop service and start service
> icon for Tomcat).
> Ryan
Re: Exception when shutting down Equinox service [message #73989 is a reply to message #73864] Thu, 14 February 2008 09:18 Go to previous message
We are using 1.1-M1.
We'll try CVS and let you know how it goes.
Patrick
> Ciao
> Frank
.... We are stuck with technology when what we really want is just stuff that works. Douglas Adams
Previous Topic:PreferenceStore not supported?
Next Topic:Architecture overview
Current Time: Wed Jul 30 15:57:47 EDT 2025
Powered by FUDForum. Page generated in 0.04144 seconds
