Home » Modeling » M2T (model-to-text transformation) » generating java code out of uml activity diagrams with Xpand2
generating java code out of uml activity diagrams with Xpand2 [message #55310] |
Tue, 13 January 2009 08:15  |
I am currently working on a code generator, generating Java code out
UML2 activity diagrams. The diagrams are currently modeled with
MagicDraw 16 and afterwards exported as EMF UML2 (v2.x) XMI. Now the
faced problem is that the whole diagram is exported, but in fact the
internal activities of the diagram are not sorted anymore in flow order.
For example, the diagram may be:
action1 -> assertion1 -> action2 -> assertion2
now after exporting the tree structure looks something like:
action1 -> action2 -> assertion1 -> assertion2
The problem now is to generate proper Java code, I have to follow the
references. Has anyone ever faced a similar problem like that with
XPand2 or probably knows a solution which already solves the problem at
the exporting step (probably with another tool or a programmatic approach)?
Thanks in advance,
Philipp
Re: generating java code out of uml activity diagrams with Xpand2 [message #55337 is a reply to message #55310] |
Wed, 14 January 2009 03:57   |
Philipp,
note that a *diagram* is only a view on the model. The order of
activities in the model does not really matter. What does matter are the
ActivityEdges connect the ActivityNodes in the order you expect. In
other words: You should not evaluate the ActivitieNodes only, but also
the flow (outgoing / incoming relations).
See UML2 Superstructure, p. 290, Figure 12.5.
Kind regards,
~Karsten
On 13.01.2009 14:15 Uhr, Philipp Zech wrote:
> Thanks in advance,
> Philipp
Re: generating java code out of uml activity diagrams with Xpand2 [message #55468 is a reply to message #55337] |
Wed, 14 January 2009 18:38   |
Karsten Thoms schrieb:
> Philipp,
> Kind regards,
> ~Karsten
>> approach)?
>> Thanks in advance,
>> Philipp
Hi Karsten,
thanks for the hints. That's in fact what I expected (following the
references).
Nevertheless this still somehow, does not solve problem, as I think that
XPand2 is not mighty enough to help me out of this dilemma. Does there
exist another M2T framework, not a template based but a visitor based
approach, as I think this would solve the problem and would relieve a
burden of work.
Thanks!
cheers,
Philipp
Re: generating java code out of uml activity diagrams with Xpand2 [message #55495 is a reply to message #55468] |
Thu, 15 January 2009 02:44   |
Philipp,
I disagree that Xpand2 would not be mighty enough. Until now I have
solved anything with this framework. The problem is that I cannot follow
your problem in more detail since I do not know the details. I cannot
imagine that the export is faulty, it would always represent your actual
model. I think you mix up what's in the diagram and what it looks like
in the model. A diagram is only a view on the model.
~Karsten
>> Philipp,
>> the ActivityEdges connect the ActivityNodes in the order you expect.
>> In other words: You should not evaluate the ActivitieNodes only, but
>> also the flow (outgoing / incoming relations).
>> Kind regards,
>> ~Karsten
>>> Hi,
>>> approach)?
>>> Thanks in advance,
>>> Philipp
> Hi Karsten,
> references).
> burden of work.
> Thanks!
> cheers,
> Philipp
Re: generating java code out of uml activity diagrams with Xpand2 [message #55687 is a reply to message #55310] |
Mon, 19 January 2009 04:47   |
Sorting in flow order would be difficult, as there is no order in a
graph such as an activity diagram. Note that it can have multiple
initial nodes, multiple end nodes and might even fork into several
parallel flows. So what would be the ordering of such a complex flow?
The UML spec is aware of that and defines the Activity.nodes reference
as unordered, so elements are stored in a set, whose iterator can return
elements in any order.
So if you want an ordering, you'll have to define the algorithm
yourself. Xpand allows you to use Xtexd, a powerful, strongly typed,
functional language to define such extensions. It can even delegate to
Java if you feel better writing stuff there.
If you have just one initial node and no forks and decisions you might
consider the following algorithm
1) find the initial node
2) find the next node by navigating the first outgoing edge and recurse.
In Xtend, that is very simple to write.
Best regards
Jan
Philipp Zech schrieb:
> Thanks in advance,
> Philipp
Re: generating java code out of uml activity diagrams with Xpand2 [message #56137 is a reply to message #55310] |
Fri, 23 January 2009 06:46   |
> Thanks in advance,
> Philipp
thanks a lot for all the answers I got so far, but I still got another
question: Does there exist any visitor based approach for generating
java code out of UML diagrams, in contradiction to the template ones,
like for example XPand2?
thanks a lot!
cheers,
Re: generating java code out of uml activity diagrams with Xpand2 [message #56375 is a reply to message #56137] |
Sun, 25 January 2009 02:31  |
Hi Philipp,
I don't know any, sorry. However, I come better along with template
based approaches anyway.
Best wishes,
~Karsten
> thanks a lot!
> cheers,
Current Time: Mon Jul 14 03:21:21 EDT 2025
Powered by FUDForum. Page generated in 0.33343 seconds
