Home » Archived » XML Schema Definition (XSD) » Error using sequence
Error using sequence [message #55302] Fri, 26 November 2004 04:48 Go to next message
Originally posted by: ooi.de.ibm.com
Hi!
I came across a funny error and have no idea why it happens.
when I run this code :
XSDComplexTypeDefinition complexType =
XSDFactory.eINSTANCE.createXSDComplexTypeDefinition();
complexType.setName("PurchaseOrderType");
XSDParticle particle = XSDFactory.eINSTANCE.createXSDParticle();
XSDModelGroup modelGroup = XSDFactory.eINSTANCE.createXSDModelGroup();
modelGroup.setCompositor(XSDCompositor.SEQUENCE_LITERAL);
particle.setContent(modelGroup);
complexType.setContent(particle);
schema.getContents().add(complexType); //error shown here
its shows the following error during runtime:
org.w3c.dom.DOMException: HIERARCHY_REQUEST_ERR: An attempt was made to
insert a node where it is not permitted.
but using only:
there is no problem.
what could be the cause of this error?
Thanks.
Re: Error using sequence [message #55384 is a reply to message #55302] Fri, 26 November 2004 07:11 Go to previous messageGo to next message
--------------020808050602050005090005
HT,
I added this code to
org.eclipse.xsd.util.XSDPrototypicalSchema.initializePrototy peSchema:
prototypeSchema.updateElement();
prototypeSchema.getContents().add(complexType); //error shown here
if (true) return prototypeSchema;
and this result is printed when I run org.eclipse.xsd.test.XSDMainTest:
<!-- ** PrototypicalSchema ** -->
<xsd:schema xmlns:EXT="http://www.example.com/SomeOtherSchema"
xmlns:PTS="http://www.example.com/PrototypicalSchema"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
attributeFormDefault="qualified" elementFormDefault="qualified"
targetNamespace="http://www.example.com/PrototypicalSchema">
<xsd:complexType name="PurchaseOrderType">
<xsd:sequence/>
</xsd:complexType>
</xsd:schema>
So I can't reproduce your problem.
I can best help if you provide a complete sample that reproduces the
problem.
HT Ooi wrote:
> Hi!
> to insert a node where it is not permitted.
> but using only:
> Thanks.
<html>
<head>
http-equiv="Content-Type">
</head>
HT,<br>
<br>
org.eclipse.xsd.util.XSDPrototypicalSchema.initializePrototy peSchema: <br>
<blockquote>XSDComplexTypeDefinition complexType =
XSDFactory.eINSTANCE.createXSDComplexTypeDefinition();<br>
complexType.setName("PurchaseOrderType");<br>
<br>
XSDParticle particle = XSDFactory.eINSTANCE.createXSDParticle();<br>
XSDModelGroup modelGroup = XSDFactory.eINSTANCE.createXSDModelGroup();<br>
modelGroup.setCompositor(XSDCompositor.SEQUENCE_LITERAL);<br >
particle.setContent(modelGroup);<br>
complexType.setContent(particle);<br>
prototypeSchema.updateElement();<br>
prototypeSchema.getContents().add(complexType); //error shown here <br>
</blockquote>
<blockquote>if (true) return prototypeSchema;<br>
</blockquote>
and this result is printed when I run org.eclipse.xsd.test.XSDMainTest:<br>
<blockquote>&lt;!-- ** PrototypicalSchema ** --&gt;<br>
&lt;?xml version="1.0" encoding="UTF-8"?&gt;<br>
&lt;xsd:schema xmlns:EXT=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/SomeOtherSchema">"http://www.example.com/SomeOtherSchema"</a>
xmlns:PTS=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/PrototypicalSchema">"http://www.example.com/PrototypicalSchema"</a>
xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/PrototypicalSchema">"http://www.example.com/PrototypicalSchema"</a>&gt;<br>
Re: Error using sequence [message #55411 is a reply to message #55384] Fri, 26 November 2004 07:21 Go to previous messageGo to next message
Hi Ed!
Here's a bigger piece of my sample programme...
static Document document;
public void createElementWithSchema(){
Element schemaElement = (Element) document.createElement("schema");
document.appendChild(schemaElement);
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setElement(schemaElement);
xsdSchema.setTargetNamespace("http://www.eclipse.org/xsd/examples/createxsd");
java.util.Map qNamePrefixToNamespaceMap =
xsdSchema.getQNamePrefixToNamespaceMap();
qNamePrefixToNamespaceMap.put(xsdSchema.getSchemaForSchemaQN amePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
qNamePrefixToNamespaceMap.put("createxsd", xsdSchema.getTargetNamespace());
xsdSchema.getContents().add(complexType);
xsdSchema.update();
xsdSchema.updateElement();
If it helps I could send the whole Java source file.
Thank you.
Re: Error using sequence [message #55437 is a reply to message #55411] Fri, 26 November 2004 07:41 Go to previous message
--------------090508090102010607080800
HT,
I don't just need a slightly bigger sample, I need the complete sample
that runs and by doing so demonstrates the problem.
Note that this code still has your *wrong *schema element in it. You
need to use createElementNS. (If you would just use
XSDSchema.setDocument, the element will be *correctly *created for you.)
HT Ooi wrote:
> Hi Ed!
> Element schemaElement = (Element) document.*createElement*("schema");
> xsdSchema.update();
> Thank you.
<html>
<head>
</head>
HT,<br>
<br>
that runs and by doing so demonstrates the problem.<br>
<br>
Note that this code still has your <b>wrong </b>schema element in
it.
Re: Error using sequence [message #592770 is a reply to message #55302] Fri, 26 November 2004 07:11 Go to previous message
HT,
<xsd:sequence/>
</xsd:complexType>
</xsd:schema>
problem.
HT Ooi wrote:
> Hi!
> but using only:
> Thanks.
<html>
<head>
</head>
HT,<br>
<br>
<br>
</blockquote>
</blockquote>
Re: Error using sequence [message #592784 is a reply to message #55384] Fri, 26 November 2004 07:21 Go to previous message
Hi Ed!
xsdSchema.update();
Thank you.
Re: Error using sequence [message #592797 is a reply to message #55411] Fri, 26 November 2004 07:41 Go to previous message
HT,
HT Ooi wrote:
> Hi Ed!
> xsdSchema.update();
> Thank you.
<html>
<head>
</head>
HT,<br>
<br>
<br>
it.
Previous Topic:Error using sequence
Next Topic:Generating JAVA classes from XSDs
Current Time: Mon Jul 21 21:00:18 EDT 2025
Powered by FUDForum. Page generated in 1.25183 seconds
