launching GDB [message #55267] |
Mon, 23 December 2002 13:42  |
Originally posted by: bangham.neocera.com
I'm trying to get g++/gdb running under windows 2000 - have searched for
some details as to how to get all this to work, but not having much luck
finding details.
Currently, I've got g++ working fine but am struggling to figure out how to
get gdb running under windows. I currently get the following error in the
log file:
!ENTRY org.eclipse.cdt.launch 4 150 Dec 23, 2002 13:38:06.140
!MESSAGE Failed Launching CDI Debugger : Error initializing: Exec
error:Launching failed
!STACK 0
org.eclipse.cdt.debug.core.cdi.CDIException: Error initializing: Exec
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.ja
va:47)
org.eclipse.cdt.debug.mi.core.CygwinGDBDebugger.createLaunch Session(CygwinGD
BDebugger.java:29)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(Loc
alCLaunchConfigurationDelegate.java:84)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfigurati
on.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog
$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:98)
The debugger tab in the launch configurations dialog is populated with
cygwin gdb debugger and gdb debugger in the combo box - but 1) it's not
clear to me if either package is installed automatically with the cdt plugin
and 2) if I need to install gdb, how do I connect it into the cdt?
thank you.
Re: launching GDB [message #62009 is a reply to message #55669] |
Wed, 12 February 2003 06:51  |
hi
got this problem too...
>>Currently, I\\\'ve got g++ working fine but am struggling to figure out how
> to
>>log file:
> I met quite similar warning.I just modified my makefile:add -g option to
> make a debug version executable file,add \\\'cygwin\\\\bin\\\\gdb\\\' into
> PATH environment variable.Then it works.
what PATH variable? in W2K? this did not help.
in Preferences of eclipse i did not find any path variable, nor in the
project reference
charlie
FUDForum. Page generated in 0.03528 seconds
