Home » Modeling » TMF (Xtext) » Galileo: Fatal error in eclipse following xText tutorial
Galileo: Fatal error in eclipse following xText tutorial [message #55249] Fri, 03 July 2009 06:23 Go to next message
I'm following the xtext tutorial
(ttp://www.eclipse.org/Xtext/documentation/latest/xtext.html) in Galileo
(Clean install, eclipse-modeling-galileo-incubation-macosx-cocoa) but when
I need to generate the language artifacts, as mentioned in Generate
language artifacts, I need the Antlr generator fragment...
----- Console message
The Antlr generator fragment couldn't be found on the classpath.
It is highly recommended to install it using the external updatesite:
'http://download.itemis.com/updates/'.
http://download.itemis.com/updates/milestones
----- End Console message
When I use the mentioned update site
http://download.itemis.com/updates/milestones and restart eclipse, eclipse
produces a startup error in the log:
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
Eclipse won't start any more... I need to manually remove the installed
features and packages, or replace the installation with a fresh one...
I've tried various releases in the update site.
Where can I get the 'Antlr generator fragment' for Galileo
(eclipse-modeling-galileo-incubation-macosx-cocoa) if it's not included
already?
Is there another way to continue the tutorial?
Does anybody else have the same problems?
Re: Galileo: Fatal error in eclipse following xText tutorial [message #55276 is a reply to message #55249] Fri, 03 July 2009 07:02 Go to previous messageGo to next message
Hi ronald,
Looks like you've installed an older version.
The update site to use with 3.5 is http://download.itemis.com/updates/
not the */milestones one.
I've updated the update site right now. Also cleaned up the milestones
sub site, so one can't get the older unsupported feature versions.
Please update.
Dennis.
> when I need to generate the language artifacts, as mentioned in Generate
> eclipse produces a startup error in the log:
> already? Is there another way to continue the tutorial?
Re: Galileo: Fatal error in eclipse following xText tutorial [message #55303 is a reply to message #55276] Fri, 03 July 2009 07:14 Go to previous message
Dennis,
Thanks for the quick reply!
Version 0.7.0.200907031240 seems to work fine.
I now can continue my journey in the DSL/xText world :)
Ronald
Previous Topic:Unicode literals in Xtext grammar
Next Topic:example grammars
Current Time: Sat Jul 12 15:30:47 EDT 2025
Powered by FUDForum. Page generated in 0.16225 seconds
