Galileo: Fatal error in eclipse following xText tutorial [message #55249] |
Fri, 03 July 2009 06:23  |
I'm following the xtext tutorial
(ttp://www.eclipse.org/Xtext/documentation/latest/xtext.html) in Galileo
(Clean install, eclipse-modeling-galileo-incubation-macosx-cocoa) but when
I need to generate the language artifacts, as mentioned in Generate
language artifacts, I need the Antlr generator fragment...
----- Console message
The Antlr generator fragment couldn't be found on the classpath.
It is highly recommended to install it using the external updatesite:
'http://download.itemis.com/updates/'.
http://download.itemis.com/updates/milestones
----- End Console message
When I use the mentioned update site
http://download.itemis.com/updates/milestones and restart eclipse, eclipse
produces a startup error in the log:
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
Eclipse won't start any more... I need to manually remove the installed
features and packages, or replace the installation with a fresh one...
I've tried various releases in the update site.
Where can I get the 'Antlr generator fragment' for Galileo
(eclipse-modeling-galileo-incubation-macosx-cocoa) if it's not included
already?
Is there another way to continue the tutorial?
Does anybody else have the same problems?
FUDForum. Page generated in 0.47611 seconds
